Vvc
i believe it allows for a variable cam profile... the engine has two cams... an economy cam for welllll economy lower down the rev range and a 'fast' cam for higher up the rev range when you boot it.
the cams are what controls the valves... the cams are basically an egg shape which turns round and as the pointy bit of the egg reaches the valve it pushes the valve open on the spring it lets fuel/air in and exhaust out (depending on what part of the cycle your in)
anyway the more round the cam the more sedate the opening and closing and more controlled the mixture is... the more pointy the cam the more forceful the opening and closing... which allows a ton more fuel in so you go faster (race cams are more "pointy")
don't you love my technical engineering jargon?
the downside of the pointy cams is ware on the valve springs and decreased fuel economy (thats why the valves and springs are usually up-rated when fast road or race cams are installed)
anyway the VVC mech. has something to do with how the cam-profile changes and i believe it has allot to do with witchcraft :yesnod:
anyway thats as much as i understand I'm sure someone (anyone really) more knowledgeable will be along shortly to educate us both! lol
jonnocash;9145 wrote: like what adam said
you mean i was right?!:OMG:
More info here
Click
MG TF LE500 27 of 500
- a Guest
- Visitor
MGFmad;9164 wrote: The inlet camshaft is split into 2 separate shafts - the shaft for cylinders 1 & 2 is driven by the main cambelt, the shaft for cylinders 3 & 4 is driven by a further cambelt of the back of the engine.
More info here
Click
Genuinely interesting, but I'm still not sure I understand it :confused:
jonnocash;9145 wrote: try here http://en.wikipedia.org/wiki/Variable_Valve_Control . like what adam said but with tech terms
Geez... I bet the guy who wrote that has at least 3 anoraks, just the sort you want to invite rouind for a meal;)
Older but certainly not wiser!
Swerving;9192 wrote: Geez... I bet the guy who wrote that has at least 3 anoraks, just the sort you want to invite rouind for a meal;)
Have to agree with you, after reading it I wished I had never asked!
does it make me any less nerdy that i ware a M&S raincoat and my engineering terms include "pointy bit" and "egg shaped thingy"
more to the point if i get rid of the rain coat can i still come round for tea?
thedigger;9190 wrote: Genuinely interesting, but I'm still not sure I understand it :confused:
Go easy on that article - it made my ears bleed:shake:
