Boot grill mesh.
I am considering installing stainless steel mesh in the opening on my boot lid.
Has anyone else done this?
Have you got any photos?
by talkingcars
I used the same mesh to cover other openings too :whistle:
The car is now being broken :nonod: and most parts are still available.
- mgtfbluestreak
I fitted some boot mesh using self adhesive pads .....you can get them in the correct size or just trim them with a pair of scissors.
Pk of 10 CABLE TIES/SELF ADHESIVE BASES (100mmx2.5mm Ties/19mmx19mm Bases)WHITE
Hi James, did this two years ago.
First I used some cheap mesh which got rusty after a few weeks. Removed it and fitted some stainless steel mesh. Easy peasy job and looks great .
Will add some photos as soon as I can.
Kind regards
Christof
Kind regards
Christof
by c.steffan
Cheers guys, I have done the side vents and have the kit to do the front bumper.
I also have brand new mesh that should have gone in a ZS front bumper and some off cuts so can do the other bits, I also have a ex kitchen bin which is just perfect to cover the heat shield over the exhaust.
by talkingcars
Some pictures following. The mesh is stainless steel which I let cut to the right size (two separate pieces) where I bought them. They cut it with a special laser-cutter.
In the third picture you can see how I fixed the mesh: First of all I placed it correctly by the help of cable ties, than I used an applicator gun with clear Pattex fitting glue. Next day I cut the cable ties - job done.
I like the look of this mesh. Hope it helps somebody.
Regards from Germany
Christof
Christof
Last Edit:9 years 9 hours ago
by c.steffan
Last edit: 9 years 9 hours ago by c.steffan.
The following user(s) said Thank You: talkingcars, cairnsys
