Timing belt one tooth out
- mgtfbluestreak
tools i used below....some mechanics may fit a belt without them....but using the correct tools makes it fool proof they rule out getting the belt wrong.....and even when the marks are alighned correctly....it is very important the belt is then fitted tightly working around in a anti clockwise position....feeding the belt from the crank first and then keeping it tight..and after tensioning the belt then turn the engine manually by hand at least twice and checking again...once you have done the belt yourself you will wonder what all the fuss was about.it is easy to get that belt of yours timed correctly has your almost there gears exposed and engine cover off etc
older none elecronic engines could be commonly found with one tooth out on the timing....has mechanics struggle to tune a badly worn engine...they could result to drastic measure by altering timing gears to get a compromise.......a cost cutting excercise to refrain from spending money
- Andy Lawrence
WHALE OIL BEEF HOOKED
- mgtfbluestreak
I had hunting problems with my TF and although Russell had checked the engine a few times and I had replaced all the normal items he eventually found that although the cam wheels were aligned the pin locating the wheels to the cam was flatened thus giving the hunting problem. Changed the pin and all is now well. So if you are checking I suggest you remove wheels and check the pin.
Cheers Brian
- mgtfbluestreak
So assuming this is a MPI.
One tooth out won't be the end of the world!
It's possible that the one tooth out was done intentionally, in order to possibly gain some perceived performance advantage.
Whether or not this was achieved, I couldn't say.
I may just be an attempt in trying to get VVC like power from a MPI.
I'd done the same thing to my old 105 series Alfa Romeo GTV 2000.
It didn't idle so good and could be grumpy at low revs :rant: , but the thing would go like the clappers once it got "on cam" and would rev way beyond the red line (in fact right off the tacho) :omg:
It was a pain in the arse in traffic, but shitloads of fun on a mountain pass :drive:
These old Alfa engines had dialed cam sprockets so as they could be indexed for this very purpose.
The idea is that the difference in the phasing of the inlet and the exhaust valves could be advantageous to performance in certain circumstances.
The phasing chosen by the original designers would've been a compromise between performance and other factors such as emissions, smooth idle, fuel economy, ease of drivability etc.
These other factors may not have had such a high priority with whoever installed the belt.
Of course the VVC engine varies it's own valve phasing automatically to achieve this.
The other scenario is that whoever installed the belt was an incompetent oath with more mechanical ineptitude than aptitude! :lol:
So I'd set it up to standard spec and go from there.
I can see by your images the engine is an MPI (non VVC) the valve/cam timing being one tooth out on the crank pulley is only 7.5 degrees out on the cams (crank pulley 24t, crank to cam ratio 2:1 -: 360/24/2=7.5) and when you look at the VVC engine the valve/cam range is adjusted over a 37 degree range.
When fitting a timing belt and you set the pulleys in the correct position it’s not always possible to get the timing marks spot on in relation to the teeth on the belt, some engine manufactures have a vernier setting on the cam sprockets so you can get the timing marks in relation to the timing belt spot on, whereas on the K series the cam sprocket to cam location is fixed by hollow dowels.
I can see the valve timing being out by one tooth on a petrol engine and still allowing the engine to run; albeit not correctly. This is only because on a petrol engine there is quite a large compression space allowing piston to valve overlap, but one tooth out on a diesel engine would definitely have piston to valve contact.
As mentioned in one of the posts above check the hollow dowels on the cam sprockets, when I was refurbing my head it looks like the cam sprocket bolts had been tightened by locking or holding the cams which distorted the dowels, make sure when you torque the sprocket bolts back up you do it by locking the sprockets not the cams or you will twist/distort the dowels.
It will be interesting if you notice any difference in performance when you have re-set the timing correctly.
Brian.
[size=10pt]Mark[/size]
95 MGF
- adamelphick
:beer: :beer: Steve
