Help where does this bit go
Just finishing off the re build but completely stuck trying to remember where this went. I think it was somewhere near the alternator heat shield. It may have had a couple of cable ties attached. It may have just been a cable support. I could not find anything in the manuals or web. Any help much appreciated. Could also do with some pictures of the wiring harness cable tie arrangement if anyone can help.
- Leigh Ping
Alternator Belt - Replacing a badly adjusted or loose alternator belt.
Alternator Belt - Adjusting an ill fitting alternator belt.
Alternator adjuster bracket upgrade
Alternator - Replacement guide.
Looks like it should go here . The mounting hole pitch is correct but unsure of its function also I would have bagged and labelled any associated fasteners but I don't have them. Have trawled all the pictures on the web but can't find anything. The two small holes look as if they were for push in cable ties.
- richandpaula
Don't think anything is located in that far bolt hole as there would be some witness marks where the spacer would go against the head; however there should be a shield behind the alternator to stop the latent heat from the exhaust manifold.
There could have been some folded metal riveted onto the bracket and the bracket may bolt under the manifold somewhere! I have just sold my TF otherwise I would have a quick look from underneath and let you know.
Brian.
Sent from my GT-I9195I using Tapatalk
http://www.rimmerbros.co.uk/Item--i-GRID000204?src=CRITEO&utm_source=criteo&utm_medium=feed&utm_term=MG+Car+Parts&utm_content=allothers&utm_campaign=LowerFunnel
Richard
Just here. Looks like cable support for the temperature sensors. The other bolt does line up it's just not been taken out yet. It could also be fitted lower down on the bell housing to help position the coolant hoses away from the exhaust. Not sure which is correct. Thanks Roy Gill after a lot of searching I managed to find another poor picture confirming this is correct. Looks like it provides extra heat shielding for the hoses and tie in point for wiring loom.
Blow-in wrote: Is it this bit?
Richard
That was the closest thing I could find too but it's a 1600 03 car and there does not seem to be a heat shield like that on my engine. Just the sheet steel one right next to the alternator and the aluminium one above that.
Replied by roy gill on topic Re:RE: Re:Help where does this bit go
Posted 8 years 10 months ago #165037Yes that's the spot, ive been putting a pre cat sensor wire down near that area and at the time your post popped up recognised that as I've dropped my wire back through the recess in it will get a picture in morning as still have engine hatch offcampsie wrote:
Oh where does this bit go, The engine still running so it does not need it :oops:
