Lucky or what?
Replied by Winko on topic Lucky or what? And now doubly lucky.....!! Make that trebly lucky!!
Posted 5 years 8 months ago #189905
Thanks Cobber.
Chris Flanagan used top spec bolts, and yet one has failed after 2 years 3 months. There has to be a reason for these failures....
by Winko
Posted 5 years 8 months ago #189906
Right....... I’ve now had a look at Roxy in the daylight and it’s not the track rod end pinch bolt that went, its the complete bush and bolt at the anti roll bar end.
So, Chris’s assertion that these failures are rare stands up.
Once again, this is something new to me. Am I just being unlucky?
Winko
Winko
by Winko
Replied by g4wam on topic Lucky or what? And now doubly lucky.....!! Make that trebly lucky!!
Posted 5 years 8 months ago #189918
Hi Winko,
a couple of questions for you .
First of all is the failure you are experiencing occurring at the joint of the Front ARB and its link or the fixings of the ARB to its bush?
1. The Bilsteins you have fitted -are they set at the hardest setting or the softest.?
2..There is some mention of additional stresses at the ARB linkages by Roger Parker ( Everyday Modifications mgf/tf 2nd Edition) when using certain Bilstein damper/coil combinations)
3. When did you have the Bilsteins fitted and what springs did you use?
regards
Mike
regards
Mike
by g4wam
Posted 5 years 8 months ago #189937
Hi Mike,
I've had breakages in two places. The first was the pinch bolt for the track rod end, which broke where the threads start. When we removed the opposite bolt, it was cracked around the head and would have failed. Last weeks failure was the bolt that fixes the ARB to the bush.
Roxy is a Sunstorm spec car - so the springs were Sports Pack 1. Chris Flanagan fitted the Bilsteins which are at the lowest setting, so she's running hard.
I'll have a look and see if I can find the Roger Parker info.
I really appreciate your help.
W
W
by Winko
Posted 5 years 8 months ago #189939
hi
the particular information I have relates to when the ARB linkages or ARB bushes are removed to gain access for suspension work of any kind.( say to add/remove suspension assemblies).
It is vitally important that the ARB bushes and ARB linkage fastenings are only loosely tightened until the car is lowered ( the suspension is loaded) , or the suspension is pre- loaded at which point all the fastenings mentioned above should be torqued appropriately.
If the fastenings ( bolts) are torqued in the suspension unloaded situation stress will build up in the bolts and lead to premature failure in the suspension areas.
Information regarding torquing up ARB fastenings is mentioned in the F and TF service manuals.
Incidentally one of your photos seems to show allen headed bolts being used -was this really the case?
Mike
Mike
by g4wam
Posted 5 years 8 months ago #189942
Hi Mike,
Thanks for the info - I'll investigate further.
Yes, the track rod end pinch bolt that failed and the one that was cracked were both Allen headed high tensile steel bolts.
Winko
Winko
by Winko
Posted 5 years 7 months ago #189973
winko
the correct bolts for the TRE pinch bolt fixings are these.( Rimmers )
https://rimmerbros.com/Item--i-FB110101
and
https://rimmerbros.com/Item--i-FX110041
torquing up and the correct method are important
Mike
and
Mike
by g4wam
Posted 5 years 7 months ago #189975
Ordered.
Thank you.
W
Thank you.
W
by Winko
Time to create page: 0.612 seconds
