Old guys freelander
- mgtfbluestreak
Offline Topic Author
Met a guy today with a engine problem..he has a freelancer with a 1800 k series petrol..on a 54 plate...his engine runs sweet but has lost its power up hill...he di scribed it has if the brakes were on..these checked...fuel filter ok....will reach speed eventually on a straight road but engine is lafargic....can anyone help.
Possibly his VCU is giving up the goat
by paulsmgf
Sound like timing, advance retard issue ECU ?
by Steve
Maybe the inlet manifold is leaking air, so an incorrect fuel mixture?
by davidgv1
- sworkscooper
Needs the fault codes reading . Pscan eu required .
by sworkscooper
The following user(s) said Thank You: talkingcars, mgtfbluestreak
Agree. Get the fault codes read.
As it's 2004 any OBD2 reader will give them.:yesnod:
As a total guess it could be clogged air filter, or partially collapsed cat.:shrug:
Calipers seizing is a common problem. Check the wheels after ajourney see if they are warm.
by coxy134
Time to create page: 0.461 seconds
