oil sump filter
- andy tyler
- Apprentice MGer
Hi
Posted recently re oil pressure light on despite changing the screw in sensor.
a friend has suggested that there is a mesh filter in the sump over the oil pick up, and that as the car has been stood for 5 yrs..despite having an oil change it could be clogged.
Is this possible?
many thanks
Is this possible?
many thanks
by andy tyler
- ChrisMGF1996
- Novice MGer
I’m having a similar problem. Did you find an answer in the end?
by ChrisMGF1996
- sworkscooper
Hi . Having fitted an oil rail to a K series MG ZR I can't recall seeing an oil strainer but it was sometime ago. I've just had a look at the Rimmer Brothers site and it has got a strainer but it's not a very good picture.
John
John
Last Edit:5 years 3 weeks ago
by sworkscooper
Last edit: 5 years 3 weeks ago by sworkscooper. Reason: Missed a bit
- ChrisMGF1996
- Novice MGer
Ah that’s interesting. My oil has been changed recently and looks a bit dirty still. I’m thinking of an oil flush first before messing around with removing the sump to clean it. I’m getting weird oil pressure light issues. Sensor changed, pressure check ok at 70psi but light flickers between 1st and 3rd under load but 4th and 5th, no issue even under load. Thinking sludge or a wire earthing somewhere!
by ChrisMGF1996
There is a mesh screen inside of the oil pick up pipe. When I installed a uprated oil rail I found the screen partly blocked with silicone sealant from some Bozo using silicone to seal the oil pan to the block rather than the correct anaerobic sealant.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Time to create page: 0.695 seconds
