TF Lower Shock Absorber Bush?
TF Lower Shock Absorber Bush? was created by adamelphick
Posted 7 years 8 months ago #176966
Hi all.... Will these replace my lower bushes on my Bilstein shocks?
Genuine OE Quality First Line Rear Upper Trailing Control Arm Bush - FSK7484
Completed
Sent from my LG-H850 using Tapatalk
Replied by adamelphick on topic TF Lower Shock Absorber Bush?
Posted 7 years 8 months ago #177064
Anyone? It seems the top rear arm and lower bush for the standard shocks are the same - so hoping Bilstein used the standard bushes too?
Wanna buy some and fit the before I start refurbishing the shocks. Thanks
Replied by Bob on topic TF Lower Shock Absorber Bush?
Posted 7 years 2 months ago #180701
Hello Adam did these fit?
My lower bushes have come up as an advisory today when I had my MOT.
Would you need a bearing press to replace them?
by Bob
Replied by adamelphick on topic Re:TF Lower Shock Absorber Bush?
Posted 7 years 2 months ago #180711
Hey Bob. I ended up talking direct to Bilstein who did me a deal on original bushes.... But I think they are the same! I used my £49 bush press off eBay.... Was very easy to do.
Sent from my VKY-L09 using Tapatalk
Posted 7 years 2 months ago #180784
The bush arrived today, I haven't tried fitting it yet but the signs are good. The dimensions tally with one advertised on ebay so I'm confident this is the correct replacement.
Thanks for posting this thread Adam it was the only one I could find to point me in the right direction. It's a big money saver compared to having to swap the whole shock absorber.
Dimensions of bush
outer diameter 40mm
outside width 24mm
inner shaft outside diameter 23mm
inner shaft overall length 57mm
inner diameter 12mm
Last Edit:7 years 2 months ago by Bob
Last edit: 7 years 2 months ago by Bob.
Replied by smudger69 on topic TF Lower Shock Absorber Bush?
Posted 7 years 2 months ago #180839
Am I right in thinking these arevtge same bushes that are fitted into the rear upper arm assembly
Posted 7 years 2 months ago #180841
smudger69 wrote: Am I right in thinking these arevtge same bushes that are fitted into the rear upper arm assembly
Yep they're the same as far as I know.
by Bob
Posted 7 years 2 months ago #180851
Yep that's them
Posted 7 years 2 months ago #180852
Bob wrote: The bush arrived today, I haven't tried fitting it yet but the signs are good. The dimensions tally with one advertised on ebay so I'm confident this is the correct replacement.
Dimensions of bush
outer diameter 40mm
outside width 24mm
inner diameter 12mm
Imagine how much I saved on the Bilsteins! LOL The bushes are really easy to change and with new lower bushes and new upper arm bushes (they're next on my list!) you have years of worry free motoring ahead ........ at least bush-wise anyhow!
Replied by BruceTF135 on topic Re:TF Lower Shock Absorber Bush?
Posted 7 years 2 months ago #180856
adamelphick wrote: I used my £49 bush press off eBay.... Was very easy to do.
What sort of bush press was this? There are loads on eBay and I'd like to try to get the right thing. Have you got an item number/link?
Replacing these bushes could save a load of money over the cost of whole suspension units.
Time to create page: 2.530 seconds
