Paint query - silvers
I'm looking for someone with metallic paint experience to answer a question, please.
I got the paint code off of my VIN plate for my 55 plate MG TF. It says MBB (Starlight Silver), but Halfords do not stock an MBB paint.
On their chart they have MG TFs listed as MNX (Platinum Silver) but that is only listed up to 2001.
Is the MNX identical to MBB, or would I be better off going for something else (considering none of the other Rover paints are more recent than 2001)?
Not all silvers are created equal, MBB will be different to MNX, to touch up with MNX will look awful.
I have the F in platinum silver. Put next to a starlight silver TF, the difference is immense. Please do not go there, it will look terrible.
- Andy Lawrence
WHALE OIL BEEF HOOKED
The separation between the different shade provided by the space between the components helps hide the difference.
Even when your using the same colour code it can be a problem.
As paint fades over time, It's hard enough to hide the difference between the "old" and "new" paint.
Some panel beaters, will mix the paint to suit the car, only using the colour code as a starting point, obviously this takes a good trained eye and a lot of skill.
Alternately, there is and old panel beaters trick, which is used when they need to paint the lower 1/2 of a car for rust repair or the top half for clear coat peel or maybe fading.
They would either paint it 2 tone in a contrasting colour or use a pin stripe to separate the two old and new shades.
There are numerous other little scratches on it that have been treated so will not deteriorate any more, but this one hasn't. Numerous Youtube videos have been watched, and I'm now armed with the local decent paint shop's contact details. I have all the gubbins required other than the paint, so will look into taking an extended lunch break sometime mid-week and making progress there.
I could get them to do it, or I could get them to mix up the paint. The former means it'll be done right first time, the latter means I can fix all the little scratches myself. Food for thought, but that's as far as I can go this weekend. Many thanks for the input so far, gents.
- mgtfbluestreak
That looks horribly like rust, you'll need to get that area back to bare metal, removing any rust scale that mat be present.ConzarTF wrote: It isn't in the middle of a panel, it is on the corner edge of the boot area (see attached).
To do the job properly you'd need to cut anything more than surface rust out and weld new metal in, but as you probably cant afford to do that, then still cut any thing more than surface rust out and patch with fiberglass filler, treat the surface rust, then use a primer coat before the colour coats and for metallic colours, finish with a clear coat.
It's important to note that you need to get the prep work right before any attempt to apply the colour coats, there will be much sanding to get it right.
- sworkscooper
John
