Compliance bushes
Compliance bushes was created by smudger69
Posted 7 years 3 months ago #179678
How much should I expect to pay a garage to change both compliance bushes
Replied by David Aiketgate on topic Compliance bushes
Posted 7 years 3 months ago #179680
I'd have thought an hour's labour plus parts would cover it.:pop:
Replied by smudger69 on topic Compliance bushes
Posted 7 years 3 months ago #179714
Just been quoted £300 to do both
Replied by Brown1972 on topic Compliance bushes
Posted 7 years 3 months ago #179726
I guess you can always get a second quote.You have to remember that garages do have to make a living,and taking an old mg apart isn't easy,
You should see some of the bills we hand out
Posted 7 years 3 months ago #179737
You could try the shim trick. Basically putting a 2 or 3mm plastic washer/shim either side of the bush. Worked perfectly for me and cost nothing but time! There's a how to available on the forum. https://www.the-t-bar.com/forum/21-david-aiketgate-s-guides/88966-compliance-washers-what-s-that-about-then
Last Edit:7 years 3 months ago by David Aiketgate
Last edit: 7 years 3 months ago by David Aiketgate.
Replied by G0RSQ on topic Compliance bushes
Posted 7 years 3 months ago #179776
Thought Davids response seemed very cheap!
That will only apply to an "F".
A "TF" is completely different design, and compliance bushes are much more difficult to replace, especially if bolts corroded!
In which case I suspect £300 is a reasonable price.
by G0RSQ
Replied by talkingcars on topic Compliance bushes
Posted 7 years 3 months ago #179867
smudger69 wrote: Just been quoted £300 to do both
Defiantly worth a second quote from one of the mobile mechanics.
Replied by adamelphick on topic Compliance bushes
Posted 7 years 3 months ago #179874
The rear compliance bushes on Felix have been knackered since I bought him...... several years of trouble free MOTs however. The trick is to make the 'clank' disappear, which only shows itself over rough roads or on acceleration. Basically you can insert larger versions of the slotted ones David created for the F between the rear arm and the compliance bush mount. I put 2 in each at 180 degrees to each other to cover the slot.... been there for a few years now!
Yet another use for an Ikea chopping board!!!!
Replied by g4wam on topic Compliance bushes
Posted 2 years 2 months ago #199949
Adam,
just came across an old post you answered about MGTF compliance bushes and wondered if you had any detailed info about how you packed out the bush movement .
thanks
Mike
by g4wam
Replied by sworkscooper on topic Compliance bushes
Posted 2 years 2 months ago #199951
Are they gold plating them ?
Posted 2 years 2 months ago #199952
Adam,
thanks
Mike
Hi Mike,
I made them up by hand out of what IKEA used to supply as their plastic chopping boards. The new ones will be too thin as you need it about 2mm thick... So you'll need to find something similar but here's how I made them:
1. Measure the diameter of the outside of the metal Bush surround. Cut 4 of these circles from the plastic.
2. Cut a hole around 1cm or so in the middle of each.
3. Cut one slot from centre to outside on each of the washers you've created, making them split washers.
4. Stick a pry bar under the lower arm and push down to give a small gap between the compliance Bush end and the subframe.
5. Slide one washer around the bolt that goes through the compliance Bush, between the subframe and the arm (the bits that are banging on each other). It should cover the whole compliance Bush and the metal outer part.
6. Slide another one on top, in the gap with the slot at 180 degrees to the first one.
7. Let the key bar pressure off and your done!
Hope that makes sense!
Posted 2 years 2 months ago #199960
Adam,
thanks for replying , I have an old compliance bush and bracket assembly which i bought some time ago to understand how they fit so i should be able to use this as a template to make the new plastic inserts if you agree .
with refence to the pry bar action, am I aiming to move the rear of trailing arm sufficiently to insert the plastic washers
understand 5 , is 6 fit another washer onto of the one you fitted in 5 but with slot at a different angle?
mike
by g4wam
Time to create page: 0.551 seconds
