Windows open (a bit) under a cover?
Windows open (a bit) under a cover? was created by NikTheGeek
Posted 7 years 4 weeks ago #181642
I get condensation on these cold mornings, all over the windscreen and it takes a while to clear. The Mike Satur glass wind deflector doesn't help either - so much for a heated rear screen!
Anyway, I bought a Mike Satur Storm Mate cover for it and I've read elsewhere that you should leave the windows partly down (an inch or so on each side) to allow air flow through the car, equalising the internal and external temperature, thus reducing condensation.
Anyone else do this? Or do you put those dehumidifier things in? Or is the cover good enough to keep the car snug and dry?
It's not a daily driver, so the hassle of putting a cover on and off isn't an issue.
TIA,
Nick
Last Edit:7 years 4 weeks ago by NikTheGeek
Last edit: 7 years 4 weeks ago by NikTheGeek.
Replied by graham1 on topic Windows open (a bit) under a cover?
Posted 7 years 3 weeks ago #181648
if it is garaged it doesn't matter, if outside 3mm each window will do the trick.but put the cover on.
by graham1
The following user(s) said Thank You: NikTheGeek
Replied by SundanceUK on topic Windows open (a bit) under a cover?
Posted 7 years 3 weeks ago #181651
Pull the carpets back in the footwells and check for water collected under the soundproofing.
Usually get a big build up of condensation when there is water inside the cockpit.
Sundance
Replied by talkingcars on topic Windows open (a bit) under a cover?
Posted 7 years 3 weeks ago #181658
I have some rock salt in an open container which helps.
I periodically dry it out on a radiator indoors.
I also have a heated front screen that works wonders.
The only problem with leaving the windows ajar is the risk of setting off the alarm.
Replied by NikTheGeek on topic Windows open (a bit) under a cover?
Posted 7 years 3 weeks ago #181669
talkingcars wrote: The only problem with leaving the windows ajar is the risk of setting off the alarm.
I wish! Despite having a 2004 TF and the alarm control box (which I have replaced) I don't have a working ultrasonic alarm. No idea why. Mind you, I don't actually know where the sensors are located, so maybe they are missing or the wires have been cut when the roll hoops were fitted (previous owner).
Replied by cairnsys on topic Windows open (a bit) under a cover?
Posted 7 years 3 weeks ago #181672
The ultrasonic alarm sensor is behind the T-bar.
Time to create page: 0.508 seconds
