Big end bearings
  • p38
Big end bearings was created by p38
Posted 7 years 3 weeks ago #181771
Hi all does anyone have an idea how much it would be to repair big end bearings on an 1.8 mgtf .
by p38
Replied by G0RSQ on topic Big end bearings
Posted 7 years 3 weeks ago #181773
Unless you have some specific reason to keep the engine block, I would be looking at replacing it with a good used one.
If big ends gone, then a lot of other work is likely to be need doing.
need to check specifically for crank shaft wear.
Unless a very high mileage engine, worn big ends would indicate a poorly maintained engine!
by G0RSQ
The following user(s) said Thank You: p38
Time to create page: 0.457 seconds
