MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ?
- mark140365
- Novice MGer
MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ? was created by mark140365
Posted 7 years 1 week ago #181941Engine cranks starter turns there is spark & fuel.
Baffled
Replied by talkingcars on topic MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ?
Posted 7 years 1 week ago #181943It sounds frustrating but could be a multitude of things.
Is yours a MEMS 3, if so stick an OBD2 reader on it and see what comes up.
Is it turning over fast enough?
How strong is the spark?
Have you double checked the timing marks?
Manual or automatic tensioner?
James
- mark140365
- Novice MGer
Replied by mark140365 on topic MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ?
Posted 7 years 1 week ago #181944Battery ok cranking fine, storng spark iridium plugs tested each plug fuel is there too,
Timing is correct & new auto tensioner working after two turns back to correct position.
Is there any way the alarm works but the mobilser stays on no letting it fire up ( but its cranking over took al plugs out 4 flames. checked fuel pressure.
- mgtfbluestreak
Replied by mgtfbluestreak on topic MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ?
Posted 7 years 1 week ago #181946Please Log in or Create an account to join the conversation.
Posted 7 years 1 week ago #181947mark140365 wrote: Is there any way the alarm works but the mobilser stays on no letting it fire up ( but its cranking over took al plugs out 4 flames. checked fuel pressure.
What is the LED doing on the dash?
Replied by countax on topic MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ?
Posted 7 years 1 week ago #181975Nigel
Replied by candaer on topic MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ?
Posted 7 years 4 days ago #181994If you have no or low compression then this is almost certainly due to the valves being forced open. It is not an unusual problem in rebuilt K series engines.
The trick is to restart the car by being towed. This usually restarts the engine. You then keep it running at approx 2000rpm and gradual ease off on the throttle - going back up to 2000rpm if it looks like stalling. This can take about 15mins. Once it ticks over without stalling the problem is cured.
- El gordo escoces
- Journeyman MGer
Replied by El gordo escoces on topic MGF WONT START AFTER CAMBELT CHANGE, WATER PUMP, CAMSHAFT OIL SEALS. ?
Posted 7 years 4 days ago #181995Bumper to low
No towing eye
Posted 7 years 4 days ago #182001Please Log in or Create an account to join the conversation.
