sill drain hole pictures
Hi all has anyone got any pictures of the sill drain holes are.
by p38
at the rear of the car inside the wheel arch look at the rear sill facing the front and you will see it, same on the front, but you have to take the wheel lining off to see it. hope this helps. I know because I was working on mine today and had to take the drivers wing off to realign my driver's door.
by graham1
- adamelphick
I thought there were several drain holes on the sill lower edges wheres it's welded to the inner panel? They are just kind of 'gaps' in the weld that stick out a bit - hence why they block up as they're so small.
by adamelphick
Time to create page: 0.463 seconds
