srs light
- Andy Lawrence
when i start the car the srs light stays on.
any ideas what ive done wrong??
WHALE OIL BEEF HOOKED
- mgtfbluestreak
- Andy Lawrence
- Andy Lawrence
But it looks like that baby has thrown up strawberry custard onto the steering wheel.
- John and Sue
2 Ohm is burger all, about the net resistance of a metre of 1mm2 stranded cable.....
Just curiarse....
- SundanceUK
The method to determine this would be to meter out the airbag and get the resistance.....however I aint too sure that I would want to be using a multimeter on an airbag det to find its resistance...the meter will put out a voltage across the load of the airbag detonator so it could calculate the resistance.
I could see the det having a reasonably low resistance value, maybe 10 - 30 ohms though, so maybe some experimenting with different value resistors could help you to find out what value works. maybe a low value potentiometer will help to find out the correct resistance value.
I myself would prefer to have a fully functioning airbag in front of me instead of a fancy steering wheel, and I do like the stock steering wheel, its comfy and not too big.
Lets hope if you get it to work, you don't have the need of a none existent airbag.
One other possibility I have just thought of is to fit a passenger airbag module and wire it to the existing SRS circuit, so that should cure the SRS light issue and at least the passenger will have a soft landing!
Best of luck
Sundance
- John and Sue
Would rather kiss an airbag than bite a steering wheel tbh.
- SundanceUK
John and Sue wrote: Aha, with it now: the airbag is gorn and the resistor is a dummy load. Unlikely you'd set off an airbag measuring the resistance as it's the impact sensor that triggers operation but I'd go at it carefully. If I remember from many years ago resistors come with accuracy tolerance bands, black, red, gold silver etc. As 2 Ohms is low I'd maybe check the actual resistor resistance. With a good meter like a Fluke.
Remember to subtract the resistance of the test leads, even quality leads have a low resistance that will give you an error when measuring low resistance.
Touch the two leads together first and allow the meter to settle and you can then get a reading to subtract from your final measurement.
My fluke leads are about 0.3 ohms, some cheaper meters will bell out at up to 2 ohms.
Agree that it is unlikely that measuring the resistance of an airbag will set it off, but I still would approach it very carefully.
I found this interesting forum post on the subject well worth reading... http://uk-mkivs.net/topic/27797-mythbustersairbags-and-multimeters/
Sundance
- John and Sue
An excellent point about lead resistance Sundance: should have remembered that Doh! Tbh, most of my Fluke work nowadays is voltage and continuity, so lead resistance not so critical.SundanceUK wrote:
Sundance
