Busted door handle
  • SundanceUK
Busted door handle was created by SundanceUK
Posted 6 years 10 months ago #183438
Came to give the TF a run this morning and the drivers side door would not open. Unlocked ok and would open from the inside.
Forum perusal tells me that a plastic bit has broken off the inside of my door handle. Sounds quite common, so I will order a replacement handle in the morning without taking off the door cards to check as I am 95 percent certain this is the case.
Anyone else experienced this? or should I check it out first.
Normally I would investigate, but I have so much on in the next couple of weeks, every hour saved is a bonus!
Hopefully a second hand handle in LEF will be easy enough to find!
Sundance
Replied by John and Sue on topic Busted door handle
Posted 6 years 10 months ago #183439
Door handle removal and replacement is fairly straightforward: door card off then socket with extension to unscrew handle. Ninja skills required to screw the bolts back in: access through holes in the door inner skin. I taped the bolts onto the socket to start the threads. You need to flip the actuating bar out of the lock too. There is a how to iirc in the How to section.
Good luck. Simple but needed 40% of my swears and 8% of my blasphemy to start the bolts: 10mm head self tap.
The following user(s) said Thank You: SundanceUK
Time to create page: 0.548 seconds
