uprated alternator bracket
did the alternator bracket today, what a pain in the rear. sore hands' headache and to top it off bleeding freezing, all sorted now, I am going to mg alfa parts in Bolton on Saturday as he is fitting me stainless steel engine cooling pipes, as well as a new belly pan as mine, was damaged due to those stupid bumps they lay down to keep you from speeding. so will be done next week:broon:
by graham1
It's a good upgrade. Fitting a new belt should be pain free in future :broon:
by Bob
Hi Graham
Next job on my list!
Did you experience any major problems with the modification (i.e. seized bolts). Did you work from under the car or through the wheel arch?
Robert
Robert
Last Edit:6 years 9 months ago
by Fisher
Last edit: 6 years 9 months ago by Fisher. Reason: spelling correction
worked from the top through the engine bay to get the socket wrench down to the bolt, and through the wheel arch, no problems with the bolts coming out, one of the easiest jobs I have done still scrapped my knuckles a bit but a job well worth doing, just make sure the lock nuts are away from the alternator body or you won't be able to lock them up. just going to get stainless steel engine cooling pipe fitted on Saturday and a new belly pan and that's it for this year, had enough for this year, do what needs doing next year, when funds are available, think I have rebuilt this since I have had it, by the way, make sure you have done all the jobs that need doing while the engine cover is off, don't be like me and have to take the bleeding thing off half a dozen times
by graham1
Thanks Graham
Looks like the engine cover of for me again!!! Just put it back after major service.
Robert
Robert
by Fisher
didn't I say so, one pain in the ass, but when you have done it all you can forget about it, all being well, but think twice and if unsure just put a few bolts in, then you haven't got the pain of removing them all again, good luck and may the gods be with you,
by graham1
Time to create page: 0.477 seconds
