SRS light
SRS light was created by MG Fan
Posted 6 years 8 months ago #184236
Hi All
Can anyone tell me why the SRS light has just lit on the dash and is it a problem. Can it be put out by connecting to a fault checker and turned off.
Thanks Brian
by MG Fan
Replied by mgtfbluestreak on topic SRS light
Posted 6 years 8 months ago #184239
This happend a few times to my tf sometime back...srs light stayed on when engines started....it eventually cured itself .disconnect the battery and leave for a 10 minutes before attempting to work on the srs...the first place to try would be the underseat connectors...maybe the car is damp with the recent weather...another place to check is damage/wear to the rotary coupler...you may read all about the srs system in the workshop manual available to download off this forum
It's always a good idea to own a obd2 scanner..mine is the torque ap on android....
There is a large section on srs in the manual..heres another extract.
Last Edit:6 years 8 months ago by mgtfbluestreak
Last edit: 6 years 8 months ago by mgtfbluestreak.
The following user(s) said Thank You: talkingcars, Fisher
Replied by SundanceUK on topic SRS light
Posted 6 years 8 months ago #184245
On most cases its the connector on the drivers side, this one is the one that gets all the strain with seat movement on the rails.
I have a dicky one also, but been ok since I last pushed it together.
Seats are coming out later this year so will be putting a better connector on then.
Sundance
Replied by MG Fan on topic SRS light
Posted 6 years 8 months ago #184256
Thanks Guys
Will check it out when it stops raining!!!
Brian
by MG Fan
Replied by talkingcars on topic SRS light
Posted 6 years 8 months ago #184266
Bluestreak's answer got it in one.
Time to create page: 0.485 seconds
