radio woos
hi, when I put my indicator on left or right my radio goes off any advice please, put a light tester on my fuse and turn the steering wheel and the light goes on and off from the fuse when I rotate the wheel left or right, when the radio is off no problems, really need good advice so any appreciated
by graham1
- John and Sue
Try checking that the radio chassis has a secure earth: these weird things are often due to a device seeking earth via another source.
by John and Sue
Thanks, John, I will do that tomorrow and let you know how it goes thanks for your help.
by graham1
- John and Sue
No probs. Also check your main battery to chassis earth is clean and tight.
by John and Sue
hi john put an earth on the radio, nothing still the same, I will check the battery earth tomorrow let you know what happens,
by graham1
thanks john battery to body earth great thanks
by graham1
- Andy Lawrence
Check the loom behind the radio for chafing.
Project drive meant that a plastic guard strip was deleted leaving a sharp edge.
WHALE OIL BEEF HOOKED
Time to create page: 0.495 seconds
