DAB Radio Aerial
DAB Radio Aerial was created by Owers19
Posted 6 years 5 months ago #186176
Hi,
Has anyone replaced the existing Aerial with a DAB compatible one?
It's time for an upgrade on the Audio!
by Owers19
Replied by Noz1966 on topic DAB Radio Aerial
Posted 6 years 5 months ago #186177
Owers19 wrote: Hi,
Hi
Yes I have. Ive left the original aerial in and put a dab one in the windscreen. I get really good reception no drop outs at all
Stu
by Noz1966
Replied by talkingcars on topic DAB Radio Aerial
Posted 6 years 5 months ago #186178
I normally retain the original aerial and use a DAB splitter to good effect.
Replied by G0RSQ on topic DAB Radio Aerial
Posted 6 years 5 months ago #186181
Same as Talkingcars here
Used an active powered splitter, so standard areal feeds both DAB and FM input.
Works fine.
by G0RSQ
  • Away
Replied by Cobber on topic DAB Radio Aerial
Posted 6 years 5 months ago #186183
I fitted a 3dB high gain antenna on a swivel mount in the opposite position to the existing antenna, so I now have 2 antennae...one for digital and the other for FM.
I get exceptional DAB+ reception, way beyond the "official" transmission range.
Replied by g7nbp on topic DAB Radio Aerial
Posted 6 years 5 months ago #186186
There were some dual band ones I was looking at on eBay a while back that looked very similar to the original other than a very slight bulge in the middle for the phasing. (1/4 wave for VHF and 3dBi collinear for dab). Looked like it would screw onto original mount. Either a passive or active splitter network would be needed as well unless radio has a combined input.
Edit: just had a look now and can't see them anymore. Typical! Personally, though I would probably go for an onglass one
Last Edit:6 years 5 months ago by g7nbp
Last edit: 6 years 5 months ago by g7nbp. Reason: Add comment
Replied by Owers19 on topic DAB Radio Aerial
Posted 6 years 5 months ago #186205
Hi Stu,
We’ve done the same on our XJR as a temporary fix.
We really wanted to go the route of a full replacement
by Owers19
