Broken Camshaft
Broken Camshaft was created by Sunlover
Posted 6 years 5 months ago #186487
Has anyone experienced a broken inlet camshaft on a non VVC MGF? Camshaft is physically broken adjacent one of the journals, with subsequent damage to valves, pistons and who knows what. The motor had recently had crankshaft oil seal replaced, and has had a new head, timing belt, tensioner, etc fitted in recent months.
I am interested if this is a known issue, a one off, or a workshop error.
Replied by NigelOBB on topic Re:Broken Camshaft
Posted 6 years 5 months ago #186488
Sunlover wrote: Has anyone experienced a broken inlet camshaft on a non VVC MGF? Camshaft is physically broken adjacent one of the journals, with subsequent damage to valves, pistons and who knows what. The motor had recently had crankshaft oil seal replaced, and has had a new head, timing belt, tensioner, etc fitted in recent months.
It’s possible the cam sprocket bolts been over torqued when fitted.
The inlet Cam was cracked on my MGTF 115. It looked like the last Garage who did the head couldn’t get the sprocket to fit so forced it on with a windy gun.. then glued the bolt in.. they also fitted cam seals the wrong way round.
Replied by David Aiketgate on topic Re:Broken Camshaft
Posted 6 years 5 months ago #186490
It's certainly not a known issue.:nonod: This is the first time that I've heard of it.
The following user(s) said Thank You: NigelOBB
Posted 6 years 5 months ago #186496
To add to my comments the Tifs cams had 86k on them and were like new. I would say the damage was done by over torquing the sprocket
Replied by davidgv1 on topic Re:Broken Camshaft
Posted 6 years 5 months ago #186498
Hi Sunlover, this is bad news.
So, who did the engine rework on this equipment?
Replied by G0RSQ on topic Broken Camshaft
Posted 6 years 5 months ago #186505
Not questioning the comments about the sprocket being over-torqued (I have no experience of this problem) but why would that cause the cam to crack and fail (assuming the fail point was not in the area of the bolt)?
Over tightening the cam rail I could understand, or using the wrong sealent on the cam rail (blocking oil passages), but I just can not picture mode of failure for cam sprocket torque!
by G0RSQ
Replied by Sunlover on topic Re:Broken Camshaft
Posted 6 years 5 months ago #186512
It was done by a local (Australia) specialist workshop, who claims experience with these cars. The break is adjacent to one of the middle journals (between cylinders 2 & 3), so I don't imagine it is related to the timing sprockets. I was wondering if it may have been that the timing was incorrectly set?
The car has under 100,000 KM on the clock.
Replied by g7nbp on topic Re:Broken Camshaft
Posted 6 years 5 months ago #186517
Certainly never heard of this on an MG, but have on a friend's off-road buggy. That turned out to be due to an over torque error when converting foot pounds to NM.
Im not sure about how consumer rights work in Australia, but here in the UK you would have a simple warranty claim against whoever fitted it. It is not something that should happen in normal use, and either parts fitted were of poor quality or were fitted incorrectly. Garage should be buying and fitting a new engine at their expense. You might also have grounds to claim for a hire car while it is off the road too.
It almost certainly will need to be a new engine from what you described sadly.
Last Edit:6 years 5 months ago by g7nbp
Last edit: 6 years 5 months ago by g7nbp.
Posted 6 years 5 months ago #186520
G0RSQ wrote: Not questioning the comments about the sprocket being over-torqued (I have no experience of this problem) but why would that cause the cam to crack and fail (assuming the fail point was not in the area of the bolt)?
Totally agree but it rears it’s head on the 75 OC every now and again. More KV6 then K-Series mind, but my wallet is still smarting from what should have been a simple belt change. Wish I had photographed the damaged cam and sprocket. They were a real mess.
Posted 6 years 5 months ago #186523
I've just been chatting with Russell Walsh of MGRoversolutions and he's never come across this type of failure. And He must have had thousands of these engines apart!
Possible manufacturing fault or cam has been damaged/ dropped prior to fitting.
He says that even a worst case engine blow up leaves the cams intact.
If you post pictures onto the forum of the cam. Damage, Russell will have a look at them.
Last Edit:6 years 5 months ago by David Aiketgate
Last edit: 6 years 5 months ago by David Aiketgate.
Replied by sworkscooper on topic Re:Broken Camshaft
Posted 6 years 5 months ago #186524
That's a real shocker . Are you going to find another 'specialist ' to sort it ? Where do you plan on getting the parts from?
John .
Posted 6 years 5 months ago #186525
David Aiketgate wrote: I've just been chatting with Russell Walsh of MGRoversolutions and he's never come across this type of failure. And He must have had thousands of these engines apart!
Working on the Ford Duratorque engine for London Taxis, the cam carrier would have the bolts forced out of the casting when the pistons said hello to the valves but I never saw a cam shaft break . It's probably been dropped .
John
Time to create page: 0.543 seconds
