Service today
Service today was created by gooseholla
Posted 6 years 4 months ago #186722
Hi all,
Had a little play about with my car today and ended up servicing it a bit. Cleaned the air filter and put new spark plugs in. Also finally found out what filter I had - it was sold described as K + N but I opened it up and it is a BMC CDA I believe:
I disconnected the battery and when I tried to restart the car it was turning and spluttering but wouldn't fire. I thought uh-oh I buggered it, but it eventually fired into life and has had no problems since.
Only worry I had was I did a code read and there were three codes, all to do with misfires: 1 x random cylinder 1x cylinder 4 and 1 x misfire low fuel. Not sure when from, whether ages ago or when the car was starting. Cleared them and went for a run, hard acceleration, idles, etc. No codes on return so will keep an eye on that.
John
The following user(s) said Thank You: cairnsys, sworkscooper, SundanceUK
Replied by mgtfbluestreak on topic Service today
Posted 6 years 4 months ago #186781
I changed the spark plugs and I'm heavy handed pulling at the ht leads....after changing my plugs it ran fine for a while...and then started misfiring ....I Could drive 50 miles smooth as owt and then a misfire...I had already changed coil packs for new and spark plugs...well that left ht leads so went out and got some new...job done....after I watched a few vids on youtube about testing leads with multimeter. ...sometimes it threw misfire code up and sometimes not...well intermittent power through the leads innit...
On changing the leads I took the old leads off and this happened.
Last Edit:6 years 4 months ago by mgtfbluestreak
Last edit: 6 years 4 months ago by mgtfbluestreak.
Replied by talkingcars on topic Service today
Posted 6 years 4 months ago #186955
The BMC CDA is a damn fine filter, been running it on my ZS's for several years.
Time to create page: 0.499 seconds
