Air bag light fault - a fix.
  • SundanceUK
Air bag light fault - a fix. was created by SundanceUK
Posted 6 years 4 months ago #186972
Fed up with firking around under my seats every time the SRS light comes on, so I fixed it forever!
Just cut out the nasty yellow plug and sockets thet lead to the pre-tensioners and re-connected via good old trust choccy block connectors!
I numbered the wires up so the polarity can be maintained if I ever disconnect them again.
Sundance
Last Edit:6 years 4 months ago by SundanceUK
Last edit: 6 years 4 months ago by talkingcars.
Replied by Bob on topic Air bag light fault - permanent fix.
Posted 6 years 4 months ago #186977
Did the ones on my ZT years ago with solder and heat shrink sleves. I had a setting for the wife shopping so I was always moving them using the memory function, I think choc blocks may have come apart.
The TF light has never come on thankfully.
by Bob
Replied by AntonyM on topic Air bag light fault - permanent fix.
Posted 6 years 4 months ago #186987
I cleaned mine with contact cleaner, and then put a small cable tie around the connector block to hold it firmly together (as I saw recommended on one of the forums ) and that also seems to have solved the problem, for now at least.
by AntonyM
Replied by talkingcars on topic Air bag light fault - permanent fix.
Posted 6 years 4 months ago #186990
Sorry Sundance but chocolate blocks are not a permanent solution in an environment subject to vibration such as a car, they will loosen over time.
Sorry Bob but soldering the terminals together is not a good solution as it makes it difficult to remove the seats from the car or the airbags from the seats, ever. There is also a risk of setting the airbag off if using an electric soldering iron.
I like Antonys solution.
Personally I just bent the terminals in the plugs slightly so they made better contact.
In the original installation the lead from the car is cable tied to the seat so that the actual connector moves in unison with the seat.
  • SundanceUK
Replied by SundanceUK on topic Air bag light fault - permanent fix.
Posted 6 years 4 months ago #186993
talkingcars wrote: Sorry Sundance but chocolate blocks are not a permanent solution in an environment subject to vibration such as a car, they will loosen over time.
The connectors will do fine for now. If you see my parallel post on .org you will see my preference for spring contact terminals.
I do have some somewhere, hidden away while I am re-building my shed.
They will be substituted when I can locate them and have time.
Until then the choccys will be much better than the original connectors.
I did look at them to see if the contacts were serviceable, by popping them out if the housing and bending them out a bit. Sadly only the male pins were do-able and the female bits were not worth bothering with.
Shame as I do like original parts where available, but these connectors are just too lightweight to be relied upon over the coming years.
Sundance
Posted 6 years 4 months ago #187191
Sorry, not been on .org since 1st July.
I am pleased to read that chocolate blocks are only a temporary measure.
Time to create page: 0.504 seconds
