Engine oil leak
Engine oil leak was created by Flyingoysters
Posted 6 years 4 months ago #187000
Hi all,
Got the TF tested today but when underneath I noticed an oil leak developing around/above the engine oil filter/housing
Any common in this area?
Cheers
Chris
Last Edit:6 years 4 months ago by Flyingoysters
Last edit: 6 years 4 months ago by Flyingoysters. Reason: Mm
Replied by graham1 on topic Engine oil leak
Posted 6 years 4 months ago #187002
it could be the oil filler tube, common fault, easey fix :broon: :broon:
by graham1
Replied by g4wam on topic Engine oil leak
Posted 6 years 4 months ago #187003
Hi-possibly just needs an extra turn on the filter
Mikw
by g4wam
Replied by G0RSQ on topic Engine oil leak
Posted 6 years 4 months ago #187006
Lots of possibilities, as this point is low on the engine, so anywhere above can cause it!
Need to clean it up with gunk and hose, then see where it is originating.
I had same symptoms, and turned out to be camshaft oil seal. Only noticed it by drips on the drive, and oil filter housing was covered in oil.
Cleaned it, then followed it up to the cam belt end of the camshafts.
by G0RSQ
Replied by davidgv1 on topic Engine oil leak
Posted 6 years 4 months ago #187007
Yes same as Gorsq, camshaft oil seal.
Found out tha these had been put in wrong way round after HGF.
Replied by Sunlover on topic Engine oil leak
Posted 6 years 4 months ago #187053
Mine was a leaking crankshaft seal.
Time to create page: 0.597 seconds
