Car ramps?
Car ramps? was created by jelly
Posted 6 years 3 months ago #187293
Hi need to get some new ramps anybody used these ebay item 252585769997 or recommend any?
Switzer Vehicle Car Ramp - Lift 2 Ton Hydraulic Jack Garage Heavy Duty Grey x 2
Completed
Last Edit:6 years 3 months ago by jelly
Last edit: 6 years 3 months ago by David Aiketgate.
Replied by graham1 on topic Car ramps?
Posted 6 years 3 months ago #187297
h i you need the extentions or you will wreck your bumpers, they sit on the front of your ramps
by graham1
  • VVC160
  • Van (not yet a camper) driver nowadays
Replied by VVC160 on topic Car ramps?
Posted 6 years 3 months ago #187300
Depending of an available slope.........
Looking for metallic trestles instead of breeze-blocks!!!!!!
by VVC160
Replied by Cobber on topic Car ramps?
Posted 6 years 3 months ago #187303
VVC160 wrote: Depending of an available slope.........
Please don't anyone copy this!
That is an unbelievably dangerous setup.
It's wrong in so many ways:
1st, It is sloping ground.
2nd, The ground bearing pressure of blocks on dirt won't be very good.
3rd, Blocks are not designed for this sort of load bearing situation.
4th, If using blocks isn't dangerous enough these ones are very narrow and to make matters worse the damned things are stacked, making for a loverly tottering tower of death!
5th, the wooden ramp frame, looks nailed together and the timber planks are nowhere near thick enough for the load.
Last Edit:6 years 3 months ago by Cobber
Last edit: 6 years 3 months ago by Cobber.
The following user(s) said Thank You: David Aiketgate, talkingcars, sworkscooper
Replied by David Aiketgate on topic Car ramps?
Posted 6 years 3 months ago #187309
VVC160 - The photo showing that incredibly dangerous way to lift a car is probably best left as a supreme example of what not to do! Please tell me you didnt go anywhere near that...
The following user(s) said Thank You: Sunlover
Replied by Raccoon on topic Car ramps?
Posted 6 years 3 months ago #187312
@VVC160: :spank: :bat:
@graham1 & jelly: I never had any issues using standard ramps without extensions...
by Raccoon
Replied by jelly on topic Car ramps?
Posted 6 years 3 months ago #187317
Ordered them so should get them and exhaust by Monday so remap might still happen ? Time will tell.
by jelly
Replied by SundanceUK on topic Car ramps?
Posted 6 years 3 months ago #187318
These are the ones I use with added Sealy extension ramps. Bought from E-Bay with built in jacking plates
Sundance
https://imgur.com/wnrsfOq
Last Edit:6 years 3 months ago by SundanceUK
Last edit: 6 years 3 months ago by SundanceUK.
Replied by davidgv1 on topic Car ramps?
Posted 6 years 3 months ago #187319
Hi sundance, I bet these would be even better if you stuck them on breeze blocks and bits of wood!!
You just couldn’t make it up, could you?
Cheers
  • VVC160
Posted 3 years 9 months ago #195086
Sorry, this has been done many times (as a free item)... Although length isn't best.......   width = length because of the stiff pallet 190 cm! But 190 cm fits fully the use!
For my safety, I had strong logs & jacks...... Mind, I studied joinery & carpentry...
Also using double blocks pile in 2019!!!!
Being over 60, I agree now the wedging does take too much time!!!  Only waiting for a more practical home................   ;)
by VVC160
Replied by talkingcars on topic Car ramps?
Posted 3 years 9 months ago #195096
VVC160 wrote: ...... Mind, I studied joinery & carpentry...
You didn't study design or physics obviously - THIS IS NOT SAFE - PEOPLE DIE TAKING LESS RISK!
Please stop doing this.
Posted 3 years 9 months ago #195098
As someone who is licenced to do high risk work, my professional opinion is this is still unbelievably dangerous.
Worksafe would pull my licence in a nanosecond if I did this, and quite rightly too!
You say that you've done this many times...... you've been very lucky so far.......don't bother buying a lotto ticket because you've used up all your luck!
Keep doing this and sooner or later your luck will run out........I'd be betting on sooner. You will end up getting seriously hurt or dead!
A warning to the kiddies.......DON'T DO THIS AT HOME!
Time to create page: 1.551 seconds
