Boot remote opening?
Boot remote opening? was created by Hogweed
Posted 6 years 3 months ago #187534
I’ve read other threads about this, but what I was wondering is – what’s all this stuff attached to the mechanism already? At first I thought it was an electronic opening mechanism already, but I guess it can’t be…
by Hogweed
Replied by SundanceUK on topic Boot remote opening?
Posted 6 years 3 months ago #187535
if it has a Bowden cable attatched to the lock release arm, then all it can be is a remote release mechanism. Not like anything I have seen before..any more pictures?
Sundance
Replied by Calico10 on topic Boot remote opening?
Posted 6 years 3 months ago #187536
I think that the electrical connections are for the alarm and boot open light and the cable goes to the key plate. When you turn the key in the lock it pulls the cable which unlocks the latch.
Best regards
Dave
Replied by Hogweed on topic Boot remote opening?
Posted 6 years 3 months ago #187538
Calico10 wrote: I think that the electrical connections are for the alarm and boot open light and the cable goes to the key plate. When you turn the key in the lock it pulls the cable which unlocks the latch.
Aaah, gotcha, that makes sense.
Thanks :D
by Hogweed
Replied by g4wam on topic Boot remote opening?
Posted 6 years 3 months ago #187545
Hi there,
just to add a bit more to this -when I last traced out the total boot wiring there was no less than 9 independent wires in the boot loom to control all the functionality -that's without any additional boot release wiring.
Its no wonder then that any breaks or shorts in the boot loom can cause electrical mayhem or at worst fires.
Regards
Mike
by g4wam
Posted 6 years 3 months ago #187549
Wondering how the picture looked different than what I have seen before, it appears your car has a cover over the boot lock rear where the bowden cable attaches to the lock. I have not seen a cover here before. Both my 04 TF's did not have one. Wondering if this was another project drive cut back....
If the cover is available, I will try to source one as it tidies up the boot a bit...apart from that, I think your boot release mechanism is pretty much standard.
Sundance
Replied by sworkscooper on topic Boot remote opening?
Posted 6 years 3 months ago #187551
Hi Sundance. Mine looks just the same with the cover over the lock . When I put a remote boot popper on I managed to cover that to match it .
John
Replied by cairnsys on topic Boot remote opening?
Posted 6 years 3 months ago #187552
sworkscooper wrote: Hi Sundance. Mine looks just the same with the cover over the lock . When I put a remote boot popper on I managed to cover that to match it .
John
It's not on my 1999 Mk2 F and I can't find it in Rimmers catalogue. If anyone knows where to source these I would be interested because as Sundance said, it does tidy the boot a bit.
Replied by talkingcars on topic Boot remote opening?
Posted 6 years 3 months ago #187554
I have a feeling that the cover comes from a ZR.
Posted 6 years 3 months ago #187558
To be fair it is the typical cheap bargain basement thing you would find on MG/ ROVER. I wouldn't expect that anyone would stock it . It's just a flimsy piece of foam . Can't say I saw it on my ZR as the lock was covered by a large plastic panel .
John .
Posted 6 years 3 months ago #187560
Umm, this was behind the "large plastic panel".
Replied by NikTheGeek on topic Boot remote opening?
Posted 6 years 3 months ago #187566
My 04 plate has that cover behind the lock...
Time to create page: 0.548 seconds
