Source of trim fixings
Source of trim fixings was created by Gavin207
Posted 6 years 3 months ago #187569
Found the following supplier https://www.vehicleclips.co.uk who supply trim clips at a reasonable price. I bought a selection and the following appear to fit the TF, I've given the equivalents from the Rimmer catalogue:
FCP-0572 EUM 10001 mushroom heads behind the seats
FCP-0318 EZM 10011 the white fixings on my TF which hold the T bar in place. They are smaller than the originals and fit more snugly on the mushroom head on the T bar.
FCP-0364 DBP 5563 Loads of applications on the TF
FCP-0009 CYH10001L Unthreaded plastic nut
FCP-0029 General fir tree fixing, I used for the boot carpet
FCP-0603 This one fitted over the fixing which holds the carpet on the top-hat fixing holding the sound insulation in the footwell.
The above is probably not exhaustive but covered the ones I was looking for at the time.
The following user(s) said Thank You: psymon, talkingcars, cairnsys, Raccoon, sworkscooper, SundanceUK, Fisher, Winko, NikTheGeek
Replied by El gordo escoces on topic Source of trim fixings
Posted 6 years 3 months ago #187600
Was given a set of car trim tools,they turned out to be invaluable when removing door cards, boot lining etc. Most importantly you tend not to break or damage the plastic grommets. Previously we removed with a screwdriver and it tended to be a bit hit or miss.
If you Google car trim tools there are plenty of options for under a tenner.
Replied by talkingcars on topic Source of trim fixings
Posted 6 years 3 months ago #187622
I got a set from TK Maxx for £7.
Time to create page: 0.498 seconds
