Front Upper Arm Shaft MG TF
Front Upper Arm Shaft MG TF was created by VX54NEW
Posted 6 years 2 months ago #187743
Hi
Does anyone know if there is any difference in part nos 2A4325 and RBR000020,I know that the first one Metro and MGF is no longer available,replaced by RBR000020.
I have managed to find a new old stock upper arm for £55 plus postage,and want to use an original shaft pin if possible .
On Ebay there is ex factory stock shaft pins listed as both part nos for less than a tenner.(but not clear on which one)
I plan to use the collar and spacer from an aftermarket kit that I had used a few months ago,but play has returned .This may be because I had to dremel one bearing case out,which caused a grove in the housing that I filled ,as the new arm was so cheap it seemed the best way to go.
I don't want to pay Rimmer Bros prices for a genuine shaft or bearing kit. (£114 for kit or £63 for shaft) I don,t mind spending £12 on original coller and spacer if this is the best way to go.
Are all aftermarket shaft kits produced to the same dimensions ie. shaft diameter and collar sizes , as I could purchase one from Rimmers,and not change the bearings but use the shaft and collars.
Has anyone used an after market pin in original bearings ?
As I have spent so much on the car,I am looking to make the most cost effective long term repair(plus its a pig of a job) just to undo five bolts! I don't want to have a third attempt.:rant: :rant: :rant: :rant:
Any expert advice on which way to go would be appreciated.
by VX54NEW
Time to create page: 0.464 seconds
