MGF Suspension - Advice Sought
  • Visitor
  • Visitor
MGF Suspension - Advice Sought was created by a Guest
Posted 6 years 1 month ago #188195
On my 1996 MGF the suspension on the right hand side goes down. I have pumped it up and it gradually sinks. I cannot see any evidence of leaks on the garage floor.
My questions are....
If the Nitrogen seal has gone I would expect the suspension to go up and stay hard, is that correct?
What else should I be looking for to correct this?
Thanks
Dave
Replied by talkingcars on topic MGF Suspension - Advice Sought
Posted 6 years 1 month ago #188198
If it was a failed nitrogen seal eventually the system would reach the correct pressure and remain there but the suspension would be rock hard.
Have you looked at the spheres to see if there are any signs of leaks around the connections?
  • Visitor
  • Visitor
Replied by a Guest on topic MGF Suspension - Advice Sought
Posted 6 years 1 month ago #188201
Yes I've had a look at the suspension, rear at the moment and cannot see anywhere where there is a leak.
I've also had a look at the front but there is no sign of leaking or fluid on the floor - just wondering if it could be pooling somewhere?
Last Edit:6 years 1 month ago by a Guest
Last edit: 6 years 1 month ago by a Guest. Reason: extra info provieded
Time to create page: 0.512 seconds
