Fog/DRL lights
Fog/DRL lights was created by g4wam
Posted 6 years 1 month ago #188257
Just wondered if anyone out there has fitted a combined fog and drl unit to an MGF or TF succesfully?
Mike
by g4wam
Replied by talkingcars on topic Fog/DRL lights
Posted 6 years 1 month ago #188260
I started converting MGF front indicators but it is sat on the work bench as other tasks have taken presidency.
IIRC the initial stumbling block was the units I had bought switched the DRL on when the indicator went off, immediately, so I had flashing orange/white/orange etc.
Replied by SundanceUK on topic Fog/DRL lights
Posted 6 years 1 month ago #188269
talkingcars wrote: I started converting MGF front indicators but it is sat on the work bench as other tasks have taken presidency.
I had this too after fitting my Halos. MOT tester did not approve and advised me to do something about it. I fitted two automotive relays, one for each indicator side with the coils energizing when the indicator circuit was turned on. (I run two wires from the indicator switch to the relay coils). The relays were wired normally closed in series with the output from the DRL controller to the Halo rings. Now when I operate the indicator, the Halos on that side drop out while the indicator flashes.
Sundance
Last Edit:6 years 1 month ago by SundanceUK
Last edit: 6 years 1 month ago by SundanceUK.
Replied by G0RSQ on topic Fog/DRL lights
Posted 6 years 1 month ago #188276
g4wam wrote: thanks for your replies -here is how I did my old MGF-just wired to be on when the ignition is turned on.
Then I fitted a switch inside to turn them off for the MOT(just in case they got fussy)
You did of course, turn them off manualy, when you turned on your headlights at night....didnt you...
I am sure you wouldnt want to dazzle oncomming traffic, and cars in front with almost twice the legal light output at night :yesnod:
by G0RSQ
Replied by The driving dutchman on topic Re:Fog/DRL lights
Posted 6 years 1 month ago #188279
Curious about your plan Talkingcars.
I played with the idea of cutting a whole in the indicator lights and glue in a ready bought combi led (indicator and drl). Is your plan like this?
Verstuurd vanaf mijn SM-G950F met Tapatalk
Replied by Fisher on topic Fog/DRL lights
Posted 6 years 1 month ago #188280
I was led to believe that if lights are fitted (I suppose this includes LED's) that for the MOT they should work. If not a fail?
Robert
by Fisher
Replied by g4wam on topic Fog/DRL lights
Posted 6 years 1 month ago #188288
Robert,
the MGF/TF was produced before the 2013 introduction of compulsory DRL in Europe, therefore whether they work are or not the current MOT doesn't really cover them . The MOT tester would look at hazardous wiring and advise or fail it was found in the DRL area though.
Mike
by g4wam
Replied by talkingcars on topic Re:Fog/DRL lights
Posted 6 years 4 weeks ago #188294
The driving dutchman wrote: Curious about your plan Talkingcars.
I played with the idea of cutting a hole in the indicator lights and glue in a ready bought combi led (indicator and drl). Is your plan like this?
Almost, I got hold of some damaged mk2 smoked indicators and the combined unit I have just fits inside, just.
Posted 6 years 4 weeks ago #188296
So you mount the combined light in the unit? But thats behind the plastic lens which isn't a flat transperant surface. In that way it wont be anyway a drl like light i fear...
Time to create page: 1.789 seconds
