SRS LIGHT ON
I have a 2004 tf and the srs light has come on,I turn the ignition on and start the car,
The light is on it blinks of then on again and stays on I only have air bags on the car
Any help will be great
If an impact is detected a signal is sent to the SRS controller and this can then activate the air bags in the MGF/TF.
The underseat plugs /sockets can get corroded or become loose -these can be yellow or red depending on model year -they need to be checked carefully.
Remove the negative terminal of the battery and wait for approx. 10/15 mins to allow the static electricity to discharge from the SRS system. Push the seat back as far as possible to get to the connectors then check them by disconnecting and reconnecting -look for corroded contacts and spay with a suitable contact cleaner not WD40. then refit the negative connector
Another area to check for SRS problems is the car battery voltage (is it at least 12volts)and charging when the car is started .
Regards
Mike
You learn something new everyday, I thought it was Safety Restraint System and deployed airbags and seatbelt pretensioners as appropriate in the event of a collision.g4wam wrote: hi there-the SRS ( Seat Restraint System) is there to monitor seat movement in the event of a serious front end impact.
The sensor is inside the SRS ECU which is under the centre consol.g4wam wrote: If an impact is detected a signal is sent to the SRS controller and this can then activate the air bags in the MGF/TF.
MG/Rover recommend a minimum of 10 minutes.g4wam wrote: Remove the negative terminal of the battery and wait for approx. 10/15 mins to allow the static electricity to discharge from the SRS system. Push the seat back as far as possible to get to the connectors then check them by disconnecting and reconnecting.....
I find sliding the seat forward and tilting forward works best.
Are you sure about what you wrote!
SRS stands for "supplemental restraint system".
Not only does it control the airbags, but also the seatbelt pre-tensioners, which are what the connectors under the seats are for.
The control unit under the dash (passenger side) is what detects the severity of an impact and triggers the airbags/seatbelt pre-tensioners.
Your comments about checking the underseat wiring are totally correct, as is a common cause of false SRS warning light. :broon:
ooppss double posted with talkingcars :whistle:
Borypops wrote: I only have air bags on the car
Do you mean you have removed the seat belt pre-tensioners?
Unless you have fitted resistors instead which fool the SR ECU into thinking they are still there you will get the warning light.
If the warning light is on the SRS system is disabled.
[size=10pt]Mark[/size]
95 MGF
The only way to really know is to read the SRS ECU through T4 test book or www.pscan.uk
I checked the leads under the seat and whamo the light went out, how you are supposed to do any maintenance unless you are a contortionist with baby hands I don’t know, probably have to take the seat out 😁
- sworkscooper
. The gorilla at Longbridge who fitted my TF seats must have used the biggest air gun posible to tighten the Torx bolts. Pity the same bloke wasn't assembling the drive shaft stake nut on both of my rear hubs ! ! ! :rant:
John
