2nd Key Fob?
2nd Key Fob? was created by Hogweed
Posted 6 years 6 days ago #188534
I’m sure it’s been asked before, but I can’t find it… I only have one key and fob for my TF 135.
Key looks like it’s a simple thing, with no electronics – no doubt because it comes with a separate fob (circular type).
So I guess I just get a key cut… but how do I go about getting a 2nd fob?
I have the original paperwork for the car, including I think all sorts of security codes and suchlike…
Thanks :lol:
by Hogweed
Replied by sworkscooper on topic 2nd Key Fob?
Posted 6 years 6 days ago #188535
Hi Hogweed .
The key fob you require ( oval type ) is called Pectron . Unfortunately that type of fob is quite expensive and needs programming to the immobilizer on the car . There is a company called Remobilze ( I think ) that will come out and supply and code the new fob . The alternative is slightly more complicated as it involves removing the Pectron unit from the inside of your TF and sending it and your only fob to Paul Brown who runs a business called Technozen and he can supply and program also .
/www.technozen-electronics.co.uk/
John
Replied by Hogweed on topic 2nd Key Fob?
Posted 6 years 6 days ago #188536
sworkscooper wrote: The alternative is slightly more complicated as it involves removing the Pectron unit from the inside of your TF and sending it and your only fob to Paul Brown who runs a business called Technozen and he can supply and program also .
John
AAAHHHHH thanks John.
I've been in touch with Paul already (months ago) as my Pectron needs attention, and I'm already going to have to take it out and send it to him (when the winter closes in). So that makes sense - I'll ask him if he can do me a fob too :woohoo:
by Hogweed
Posted 6 years 6 days ago #188538
Yep , Paul is a great guy and he knows his stuff . I had him replace the relays in my Pectron SCU and he also worked his magic on a fob that had a problem . Just be aware that you need a Torx + bit to remove the SCU and these bits are not that common to the usual bits in stock at your local 'Screwfix' .
John
Posted 6 years 6 days ago #188539
sworkscooper wrote: Yep , Paul is a great guy and he knows his stuff . I had him replace the relays in my Pectron SCU and he also worked his magic on a fob that had a problem . Just be aware that you need a Torx + bit to remove the SCU and these bits are not that common to the usual bits in stock at your local 'Screwfix' .
John
Yeah thanks, I read everything on his site... pretty sure I have those bits SOMEWHERE...
by Hogweed
Replied by talkingcars on topic 2nd Key Fob?
Posted 6 years 6 days ago #188547
I've managed to loosen more than one of those security torx screws with a pair of mole grips.
The following user(s) said Thank You: sworkscooper, Hogweed
Posted 6 years 6 days ago #188550
talkingcars wrote: I've managed to loosen more than one of those security torx screws with a pair of mole grips.
Took the MAF sensor out of my tractor - sorry, Rover 75 diesel that way 😉
by Hogweed
Replied by The driving dutchman on topic Re:2nd Key Fob?
Posted 5 years 11 months ago #188585
If the torx isnt that large I use to hit the centre with a flat screwdriver and a hammer. Usually the centre pin comes out easily and then you can use a standard torx bit.
Verstuurd vanaf mijn SM-G950F met Tapatalk
Replied by sworkscooper on topic Re:2nd Key Fob?
Posted 5 years 11 months ago #188586
Err, I don't think that's a good idea. Especially if the Torx are as tight as the ones in my TF. Each to their own I suppose. :nonod:
John
Replied by SundanceUK on topic 2nd Key Fob?
Posted 5 years 11 months ago #188606
Most of the old MG dealers that were active when MG-Rover went bust and are still trading should be able to supply and program a new Pektron keyfob.
As long as you have the barcode that is supplied with the new fob the MG agents that still have a programmer can match the fob to your SCU.
My TF only had one key, but Endon Services who sold me the car back in 2015 got a spare key and fob for me and programmed it to work with my car. They explained what needs to happen. As far as I know Endon have stopped trading in cars, but are still a parts supplier and may be able to still program Pektron units for anyone around the Staffordshire area that may need one doing.
Sundance
Time to create page: 2.457 seconds
