Alarm going off during the night
I honestly believe that the microswitches will still need to be fixed by either replacing the offending door lock or repairing the switches in cases where the alarm goes of at random , or just disconnect the small loom connector .
Mike
- BruceTF135
Replied by BruceTF135 on topic Alarm going off during the night
Posted 5 years 11 months ago #188787sworkscooper wrote: I had the same issue with my TF last year , in that it wouldn't recognise the EKA . I changed the door lock on the O/S door and it made no difference at all .Once I had sent the BCU to Paul at Technozen , the problem dissappeared as he had waved his wand over it .
John
Thanks, John. It sounds Like I need to speak to Paul, then. The irony is that I contacted him in the first place when I wanted a second fob but he directed me to B&G as he didn't have any in stock...
- BruceTF135
Posted 5 years 11 months ago #188788g4wam wrote: the drivers door side microswitches do indeed allow the EKA code to be entered -but if the EKA code was corrupted in the SCU it wouldn't match so wouldn't work.
Mike
Ah! Just saw this - it was on the next page. OK. before I arrange to get my unit to Paul, I'll check out the micro-switches on the drivers door.
I wish there was room to fully open the car's door inside the garage as it's a tad chilly outside.
Can't believe something as small as a spider could trigger the alarm...?
Before anybody says it, no tarantulas in N Ireland - it's too cold
graham1 wrote: good god, that cat s bigger than our dog.
Heh - yeah :lol:
That was a few years ago. He's all grown up now.
Weighs over a stone... but is pretty affectionate.
I stumbled outside, stopped the noise with the fob, left the boot slightly open to stop it re-arming, and went back to bed. Now, having just got up again, I went out, closed the boot, and locked the car with the key in the door, to test if it’s the volumetric sensors.
However… when I turned the key, it locked etc, but my horn beeped briefly. On my Rover 75, this means you’ve left a door/boot open somewhere – does it work the same way with this Pektron system?
If so, it would obviously help me to isolate the problem…
Cheers guys
Update: right, just now the horn started going, so if I've done it right, this means it isn't the volumetrics... so does the horn beep on locking with the key also indicate a door switch?
Thanks
- sworkscooper
Replied by sworkscooper on topic Alarm going off during the night
Posted 5 years 9 months ago #189351I did also suggest that you may need to have the alarm sensetivity turned down but I think that can only be done by the MG/Rover T4 system.
Hope this helps you .
John
sworkscooper wrote: Hi. Yes that's what my TF does when I have left anything open . Well you need to test the switches that operate the the doors and the bonnet. The boot however is operated via a switch that is incorporated into the locking latch . When I looked at mine when I was fitting a remote boot popper I found quite a bit of corosion on the point where it actually earth's out when the latch closes . There could of course be a problem with boot wiring harness where the loom follows the hinge into the engine bay . That is well known area for problems. I have included a picture that shows the rear of the boot latch and in front of my finger is the earthing point for the latch .
John
Thanks again John
How do I check the harness - my old M3 had this problem, many years ago, and I seem to remember having to cut all the insulation off etc to inspect it
- sworkscooper
Posted 5 years 9 months ago #189353John
sworkscooper wrote: Does locking the car with the key stop the alarm triggering at night ? If it doesn't go off when locked with the key it could be the interior sensing is too keen .
John
No, I locked it with the key this morning, and a short while later it went off - so I have to assume it's not the internal sensors, I guess
- sworkscooper
Posted 5 years 9 months ago #189355John
