engine oil sump bolt
- BruceTF135
talkingcars wrote: The sump plug washer is brass or copper and crushes when you tighten the plug, it should be discarded and replaced every time you change the oil. They are only a few pence.
I think they are aluminium; certainly, that is what I have always been supplied. And yes, replace every time.
- mgtfbluestreak
14mm x 22mm x 2mm
Cheers
mgtfbluestreak wrote: I prefer dowty washers..🙄
Would that be a good idea in an area that can get jolly hot?
- SundanceUK
Sundance
