Front fog lamps
Front fog lamps was created by Ousewanderer
Posted 5 years 9 months ago #189318
My 2002 TF160 is rare in that it has a factory fitted front fog lamp loom but no fog lamps. Having obtained and fitted a pair of front fog lamps and a genuine MG rover switch I have hit a full stop in the proceedings.
The switch illuminates correctly but there is no relay click and the fog lamps don’t illuminate. Can anyone advise where the relay and fuse are located because my search has so far drawn a blank .
Last Edit:5 years 9 months ago by Ousewanderer
Last edit: 5 years 9 months ago by Ousewanderer.
Replied by talkingcars on topic Front fog lamps
Posted 5 years 9 months ago #189322
I have a feeling that it has to be switched on in the BCU.
Replied by Roverlike on topic Front fog lamps
Posted 5 years 9 months ago #189327
What type of fob you have: oval with logo in the middle or square one with two buttons?
Replied by Ousewanderer on topic Front fog lamps
Posted 5 years 9 months ago #189328
It’s the earlier 2 button fob .
Posted 5 years 9 months ago #189337
Front fogs relay is the one named C0024. The next one beside named C0019 is Cooling Fan 1 relay. Black box on the left is engine bay fusebox.
Fuse would be in passenger compartment fusebox number 26 rating 10 amps
You also have more info on relays and fuses here: https://forums.mg-rover.org/mgf-mgtf-12/mg-f-tf-fuse-relay-listing-487819/
Last Edit:5 years 9 months ago by Roverlike
Last edit: 5 years 9 months ago by Roverlike.
Posted 5 years 9 months ago #189341
Many thanks for that, but the mystery deepens !
The wiring to the front fogs is present, the wiring to the switch is present, but no relay or relay holder . Any suggestions ?
Posted 5 years 9 months ago #189342
I would suggest to trace wiring from frknt fogs in the engine bay and see where the wires go. Hopefully that will lead to some new information, since relay should be either in engine bay, or behined fusebox in the passenger compartment, tucked away.
Posted 5 years 9 months ago #189443
Thanks to all for suggestions. Eventually located the relay block behind the glovebox. Plugged in a yellow relay and fog lights now work correctly.
Posted 5 years 9 months ago #189444
Thank you for your feedback. Glad you sorted things!
Time to create page: 0.508 seconds
