FUD100610 or FUG000030 for boot lock
I have a late 2004 TF115 and want to fit a remote boot switch. I've seen reference to both the above actuators from other Rover models being fitted to TFs. My understanding is that the FUG000030 is driven open only, but FUD100610 is driven open and closed for locking. Does this mean that FUD doesn't return by spring when power is removed, or does it have a spring return, and the locking is by applying a seperate voltage? Any guidance appreciated.
by Gavin207
Replied by talkingcars on topic FUD100610 or FUG000030 for boot lock
Posted 5 years 8 months ago #189615
Closing the boot lid locks it so you only need an actuator that unlocks.
by talkingcars
The following user(s) said Thank You: Gavin207
Replied by Gavin207 on topic FUD100610 or FUG000030 for boot lock
Posted 5 years 8 months ago #189620
Thanks. The question I should have asked is can you use FUD100610 on a TF and just wire it up to open the boot only?
by Gavin207
Replied by cairnsys on topic FUD100610 or FUG000030 for boot lock
Posted 5 years 8 months ago #189621
I fitted a FUD100160 to my MGF and it works fine. :broon: :broon: :broon:
Robin
by cairnsys
- sworkscooper
Replied by sworkscooper on topic FUD100610 or FUG000030 for boot lock
Posted 5 years 8 months ago #189622
Yep , same on mine .
john
john
by sworkscooper
Posted 5 years 8 months ago #189624
Brilliant, many thanks, that makes life easier, there are more FUDs than FUGs available.😀
by Gavin207
Posted 5 years 8 months ago #189633
Following on, can you confirm which pins on the socket to connect to please - I haven't got a FUD yet, but I believe they have more than 2 pins?
Ignore me - just found a thread on the MGF Register which confirms it only has two pins.
Last Edit:5 years 8 months ago
by Gavin207
Last edit: 5 years 8 months ago by Gavin207. Reason: Update
Time to create page: 0.493 seconds
