Long Journey Engine Cleaners
- Martinm760
- sworkscooper
John
If you've quite a lot of fuel in the tank already, then it would make sense to bang in some high octane and Reddex, so it gets mixed in the tank. Then top up on the trip up, as necessary. However, if you’re planning to have her off the road for a while, try to leave her with a fairly empty tank. That way you can add fresh high octane when she comes up from her slumbers, counteracting stale fuel starting problems.
Enjoy the drive. When Roxy’s behaving I do Ayrshire/Skipton/Leeds on a Monday; business mileage during the week and then Yorkshire up to Ayrshire on the Friday. That can mean anything from 500 up to approaching 900 miles in a week - and not a boring one amongst them.
Safe journey.
Winko
When you do start using the car again the first fill should be high octane to dilute the stale fuel.
- mgtfbluestreak
Or you could put a tiger in your tank!
- Martinm760
- sworkscooper
Martinm760 wrote: Made it! Nine hours including two stops at service stations. As it was already full of Tesco fuel I opted for the Reddex. The drive was more comfy than I expected, just a bit noisier than normal because I put the hard top on it. Odd that the hard top makes it noisier?
Well done.
The trick with noise is to pop the hard top in the garage (or back garden or wherever you can) and go every where with the roof down (unless it's raining) as that is quietest.
