Amber engine management light - intermittent flashing
Amber engine management light - intermittent flashing was created by Winko
Posted 5 years 7 months ago #189951
Hi all,
From time to time Roxy's amber engine management light will start flashing. Typically this is on the motorway when I've gone over the brow of a climb and I lift off the throttle to keep to the speed limit. As soon as I hit the throttle again the light goes out, and if I don't hit the throttle, the flashing stops after 8-10 blinks.
I've done a throttle position re-set, and there are no error codes showing.
Any ideas?
Winko
Any ideas?
Winko
by Winko
Replied by talkingcars on topic Amber engine management light - intermittent flashing
Posted 5 years 7 months ago #189959
The official advice is to stop as soon as possible.
However as it only lasts a few seconds I wouldn't panic just yet.
First thing to do is to get a code reader on the car.
by talkingcars
Replied by Gavin207 on topic Amber engine management light - intermittent flashing
Posted 5 years 7 months ago #189966
Manual says:
illumination while driving indicates an engine fault:
- if car drives normally, arrange a service appointment
- if light flashes and / or car does not drive normally, avoid high speeds and seek immediate assistance
My used to come on if I'd had the car idling whilst fiddling with it, and go out after a couple of decent runs, so I suspect it was possibly something to do with emissions, yours could be mixture related by the sounds of it?
by Gavin207
The following user(s) said Thank You: Winko
Replied by Winko on topic Amber engine management light - intermittent flashing
Posted 5 years 7 months ago #189972
Thanks TC, thanks Gavin,
Both my local garage and I have used a reader and there are no codes showing up. I too suspect it's a fuelling issue.
Maybe the next step is to run the car with the OBD reader in place to see if something dramatic shows up, but that'll have to wait till I have a passenger aboard, as the issue normally arises on the motorway.
I'll have to keep looking.
Winko
Winko
by Winko
Posted 5 years 7 months ago #189979
The www.pscan.uk has the ability to record live data.
by talkingcars
Replied by NigelOBB on topic Re:Amber engine management light - intermittent flashing
Posted 5 years 7 months ago #190040
Could be a misfire issue due to coils, leads or plugs breaking down. Had a similar issue with mine over Xmas.
by NigelOBB
Time to create page: 0.495 seconds
