MGF Oil Temp gauge not working
My oil temperature gauge doesn’t work. I’ve replaced the sensor without success. I tested the gauge itself by applying a voltage to it and it moved. I’m guessing now that there’s a break in the wire somewhere. The multi plug looks sound. Does anyone know if there is a common break point in the wiring?
by Smith
Hi and welcome to the forum.
Have you tried testing the wiring by applying voltage to the plug for sensor?
And it maybe a silly question but are you making sure the oil is actually warm enough?
It normally takes up to 5 miles to get enough heat into the oil for the gauge to start reading.
James
James
by talkingcars
Yes, I've tried applying voltage at the plug, but the gauge doesn't move, that's why I think it's a break in the wire. If I apply the same voltage at the gauge directly, it goes to nearly full deflection. The gauge never moves, even after a few hours on the motorway.
by Smith
Time to create page: 0.470 seconds
