there's a new MG model available in Thailand...
there's a new MG model available in Thailand... was created by Raccoon
Posted 5 years 9 months ago #190180
by Raccoon
Replied by Cobber on topic there's a new MG model available in Thailand...
Posted 5 years 9 months ago #190181
Lets hope they keep the horrid thing in Thailand!
Replied by sworkscooper on topic there's a new MG model available in Thailand...
Posted 5 years 9 months ago #190183
Ala LDV ? Formerly Leyland -DAF- Vans . :(
Last Edit:5 years 9 months ago by sworkscooper
Last edit: 5 years 9 months ago by sworkscooper. Reason: Forgot a bit !
Replied by talkingcars on topic there's a new MG model available in Thailand...
Posted 5 years 9 months ago #190184
No one can accuse them of badge engineering......
Replied by mgtfbluestreak on topic there's a new MG model available in Thailand...
Posted 5 years 9 months ago #190212
Yes I thought that was a ldv at first sight.....whatever next?
Posted 5 years 9 months ago #190213
Looks remarkably similar to the LDV Maxus . I thought a Russian company had bought the tooling but might be owned by a Chinese Co.
Replied by Raccoon on topic there's a new MG model available in Thailand...
Posted 5 years 8 months ago #190223
it's a rebadged LDV Maxus V80 apparently.
by Raccoon
Posted 5 years 8 months ago #190225
Ldv below.
Nothings really changed has it! ....mg has been badge engineering for decades....this picture of a mg below ain't much different from the austin 1100 my dad owned..
Last Edit:5 years 8 months ago by mgtfbluestreak
Last edit: 5 years 8 months ago by mgtfbluestreak.
Posted 5 years 8 months ago #190226
Yes very true . It's to be hoped they are fitting a better engine than the truly dreadful Chrysler VM engine that was fitted to the Maxus and the London Taxi TX4 . I have seen engines with delivery mileage seize up due to the crap design of the centre main carrier
. They might have improved it by now but that engine was a bag of nails . Makes the K Series engine look brilliant.
John
Last Edit:5 years 8 months ago by sworkscooper
Last edit: 5 years 8 months ago by sworkscooper. Reason: Missed a bit
Posted 5 years 8 months ago #190227
I remember doing a routine service on a VM engined TX4 taxi which included an oil and filter service plus auto gear box service ,went on a short road test and checked the 'kick down ' gear change at about 30 mph and the engine just locked up . I drifted to the side of the road and thought .....ok. ....Did I tighten the sump plug ? ? ? Got out and yes the plug was still there . Did I forget to put oil in the engine ? Nope ......full of oil ! Engine solid ! Recovered back to workshop and found that the engine had locked up on the center main bearing . Mileage of engine, 12000 mls . As I say they might be better now but compared to the Nissan engined TX1 which went on for ever , the VM Chrysler unit was pants ! I'll get off my soap box now . :nonod:
Posted 5 years 8 months ago #190243
I had a brand new ldv pickup truck in about 2005...it had the ford transit running gear......not a bad engine but that dual mass flywheel sure gave it problems...I coverd 6000 miles and heard what I discribe has a chuntering....the method of the day was to take the crank sensor out and metal swarf had collected on it....apparently this was a fault with them.has the rivets holding them together would self distruct. ..the next thing I think the starter would give up.........had dual mass flywheel replaced under warranty to find it went again after about the same mileage....in the end it had a solid flywheel fitted has a conversion but it was horrible in traffic jams...
Posted 5 years 8 months ago #190247
That would be the Ford Duratorq engine with the dual mass flywheel. On the London Taxi when I was employed by them I could do a gearbox out ,clutch assembly out, dual mass change in 50 mins . Due to Ford lying like a gud un to The London Taxi Co when we used their powertrain about problems with the DMF , we would regularly get half a dozen customers in per day wanting their cabs sorting out . The crud that clogged the starter motors from the flywheel was like powdered metal . The amount of warranty back then was truly amazing .!
John
Time to create page: 0.485 seconds
