Stepspeed reversing light switch
- BruceTF135
- Away Topic Author
On the manual TF, the wiring for the reversing light switch is a handy place to pick up a switched +12V feed. The switch is connected to the loom by two standard bullet connectors which can be fairly easily accessed on top of the gearbox. Is it the same on a stepspeed?
The TF wiring diagram suggests that both have similar wiring but with different switches. The Rimmer parts drawings don't really help as I cant find the reversing light switch in them.
Can anyone help, please?
Replied by talkingcars on topic Stepspeed reversing light switch
Posted 5 years 6 months ago #190376BruceTF135 wrote: ......The Rimmer parts drawings don't really help as I cant find the reversing light switch in them.
Have you checked the part numbers?
- BruceTF135
- Away Topic Author
On the Rimmer website, do you mean?
Yes, for the manual box the reversing light switch is easy to find. It's on the "MGF and MG TF Gearbox Casing and Reversing Light Switch" drawing. Part no CDU51.
On the drawings for the auto gearbox, I cannot find the reversing light switch anywhere (unless it's called something else?).
Black female connector part # YPC10250 (connector reference # C0268).
It has 4 pins, pin #2 green/yellow & pin #4 green/black are the reverse light connections.
You would need to intercept the green/yellow wire to utilise this circuit
Posted 5 years 6 months ago #190389BruceTF135 wrote: On the Rimmer website, do you mean?
I tend to click on the part and see what it fits, in this case lots of manual Rovers and Range Rovers but no manual cars.
- BruceTF135
- Away Topic Author
Cobber wrote: OK, I just checked the workshop manual wiring diagram, it would appear to be a combination switch park/neutral (inhibitor) with 4 pins, located the lower left side above the trans oil pan, under the LH drive shaft.
Thanks, Cobber, that is quite helpful. So the switch is definitely different from that fitted to manual gearbox. The 12V feed is the same colour green/yellow but it seems unlikely that it will be so easy to tap into in the CVT as it is in the manual box. I guess I'm going to have to find a stepspeed and have a look underneath. Either that or find some other convenient place to pick up 12V at the back of the car.
- BruceTF135
- Away Topic Author
Thanks, TC. I know about the manual gearbox but it wasn't clear at all which was the reversing light switch on the CVT/auto/stepspeed gearbox. Cobber has pointed me in the right direction for that now and it looks like it is probably part no UHB100170, the 'inhibitor' switch. Unfortunately, this doesn't answer my original question which was actually about the wiring to the reversing light switch. If I had the car to hand, I think that it would be easy to get an answer...
Thanks.
