MGTF Gearbox
Hi all,
just wondered if anyone out there in MG land could offer any words of wisdom on the following.
I have what appears to be a clutch slip in first gear except I cant see any increase in engine revs during the slip.
The slip occurs on an incline in first gear .
The car shudders during the slip .
other gears seem to be ok.
the shudder can be reduced by revving up during the first gear start.( like a learner would- say)
does this definitely look like a clutch /flywheel change? or could it be an engine /gearbox mounting?
thanks
Mike
thanks
Mike
by g4wam
Sounds like your clutch is knackered!
- sworkscooper
Well , judder and slip can be separate issues but can happen together . Judder is sometimes related to oil contamination of the friction plate , broken springs in either friction or pressure plate . I would rule out the flywheel as it is solid and not dual mass . Slipping depending on the severity should occur in all gears . If you put the car in third and try to pull away from a stand still , a good clutch should stall the engine . As always it's not easy to diagnose a fault from a distance ! :nonod:
by sworkscooper
thanks for that analysis-what I can add is that I accidentally overfilled the gearbox a few months ago but i have since drained the box .
took out 3 liters ( max is 2.5 liters drained) and refilled with 2 litres of the correct fluid.
The 3rd gear test as you suggested, behaves just the way you described.
thanks for the comment on the flywheel.
Do think I can rule out engine mounts
Mike.
Mike.
by g4wam
- sworkscooper
Well I dunno really as you started by saying you had slipping . I think that the o/s top mount has a tendency to part company so it may be worth investigating . I know when I changed the cam belt on my TF the top mounting broke so it is a posibility.
John
John
by sworkscooper
thanks for your replies, I have recently found something pertaining to my gearbox and juddering issue that points to a problem on the o/s engine mount bolts.
does anyone have any information relating to o/s engine mounts and snapped or missing bolts?
I will check this area on my MGTF as soon as I can
Mike
Mike
by g4wam
g4wam wrote: …….took out 3 liters ( max is 2.5 liters drained) and refilled with 2 litres of the correct fluid.....
How do you overfill, or underfill for that matter?
With the car level you fill through the filling hole on the side until oil starts to dribble out, that will ensure the oil level is correct.
Do not underfill.
by talkingcars
Time to create page: 0.557 seconds
