Some work carried out
Old Rusty back box replaced. It came with a brand new SS downpipie and flexi so a backbox was needed to finish off.
Brake callipers were desperately needing freshen up.
Next was new plugs oil and filter and a new rocker gasket which was weeping. Its still weeping even after the new gasket
Next was new disks and pads as my fronts were a little warped. I also wax oiled the arches.
The underside has been fully wax oiled and its been done to a good standard.
Changed my front top ball joint, Track rod end, Drop link and bottom ball joint nut and bolt today. Also greased the upper arm while i was there.
My grinder is my best friend !
I bought a machine polisher and I'm still getting used to it but the results on the TF are not bad at all.
by Tunny
You have been busy - nice working space.
by talkingcars
The following user(s) said Thank You: Tunny
not a bad days work :broon:
by G0RSQ
Time to create page: 0.479 seconds
