Hardtop rear clamps
Hardtop rear clamps was created by Sandy54
Posted 5 years 4 months ago #190820
Hi gents,
Nothing new about the subject, but I haven't seen the answer to my problem.
I've just bought a hardtop for my 2004 MG TF135. The car is Cool blue as is the hardtop. I assumed it would have come from a similar aged car.
The fron clips align fine and apart from the fastenings, which I'll replace the hardtop is in good condition. I can't find the wire for the heated rear window but Best of British have pointed me in the right direction. It's probably fallen down the void in the 'door pillar' area. I need to remove the hardtop to see that, but I'd like advice about the rear clips first.
The rear clips misalign by about 20mm, not a bit! I can't see any adjustment, I've accessed the mounting bolts and the car hooks are positively located. The hardtop clips are bolted on.
The car doesn't seem to have had a hardtop fitted before, I've bought and fitted the switch and relay for the HRW and bought a lead to connect to the demister connections.
Thanks in anticipation for any advice or information.
by Sandy54
Replied by talkingcars on topic Hardtop rear clamps
Posted 5 years 4 months ago #190826
Hi and welcome to the forum
Have you tried doing the rear catches first?
James
Last Edit:5 years 4 months ago by talkingcars
Last edit: 5 years 4 months ago by talkingcars.
Replied by Sandy54 on topic Hardtop rear clamps
Posted 5 years 4 months ago #190828
No I haven't. The car is away at the moment, I'll try it when memsahib returns from work.
Thanks for the suggestion.
Kind Regards
Sandy
by Sandy54
Posted 5 years 4 months ago #190830
Thanks James,
tried the rear clamps first and they stayed put when I tightened the front clips. I wouldn't have thought the hardtop would have distorted so much. Need to adjust the clamps slightly, but they're in place now.
Well done
Kind Regards
Sandy
by Sandy54
Replied by g7nbp on topic Hardtop rear clamps
Posted 5 years 4 months ago #190831
It's also a good idea to closely check the fit of the windows once you have the hard top fitted. What is a good seal on the soft top may not be as good on the roof.
Wind them up and down a few times, and check the fit. Also a good idea not to slam the doors too hard until you have checked this.
You may be lucky and have a roof / soft top combo that are fairly close, but sadly many people don't and have the hassle of having to take door cards out and adjust the window height each time the hardtop goes on or off (a reason why so many never spend much time on the car).
by g7nbp
Replied by Cobber on topic Hardtop rear clamps
Posted 5 years 4 months ago #190832
The only hardtop you should ever need:
Time to create page: 0.989 seconds
