No speedo
No speedo was created by SMCC
Posted 5 years 4 months ago #190949
Hi. I bought a 2005 TF a few weeks ago. The speedometer doesn't work and the epas works most of the time even at high road speeds. Very occasionally it doesn't work at all. I've changed the speedo transducer and swapped out the instrument panel to eliminate the speedo itself with no change. Any clues on where best to start checking for wire breaks, poor earths, bad connectors etc?
Thanks
by SMCC
Replied by talkingcars on topic No speedo
Posted 5 years 4 months ago #190950
Hi and welcome to the forum.
The speedo works on a digital signal from the transducer, the EPAS then gets a feed from the speedo to work.
No speedo normally means a fault in the signal from the transducer but if the EPAS is working and the speedo isn't it suggests a problem with the wiring connection on the speedo.
One last bit of info required, is the milometer working?
James
Replied by SMCC on topic No speedo
Posted 5 years 4 months ago #190959
Thanks James. I hadn't noticed whether the milometer was working - I think it is but the tripmeter doesn't seem to be.
by SMCC
Posted 5 years 4 months ago #190961
Thanks
by SMCC
Posted 5 years 4 months ago #190962
If it helps there are wiring diagrams in the drop down menu in the community tab at the top of the page.
The following user(s) said Thank You: SMCC
Posted 5 years 3 months ago #191069
Hi again James. No the mileometer is not working. Is that an indication of where to look?
Thanks
Steve C
by SMCC
Posted 5 years 3 months ago #191109
I would start by checking the wiring between the transducer and the speedo.
Posted 5 years 3 months ago #191248
Sorted. Broken sensor wire in the engine harness.
by SMCC
