Throttle Position Sensor (TPS) Plug
- northernboy
- Apprentice MGer
My 1.8 TF was idling around 1500 and ODB2 reading indicated a faulty TPS as the throttle was stuck at 100%.
After a bit if investigation, I found one of the wires feeding the plug had snapped right up against the plug so the TPS was not getting the required 5 volt feed.
I managed to make a temporary connection and reset the TPS and all seems good.
My question is now where can I get a replacement plug for these so I can re attach the existing cables again.
I have searched but haven't seen any that look like they will fit?
any suggestions please?
by northernboy
Replied by davidgv1 on topic Throttle Position Sensor (TPS) Plug
Posted 5 years 3 months ago #191233
Hi,
Try Rimmer brothers.
I can see on their site plug number SLD100080.
Check this out.
Cheers
Check this out.
Cheers
by davidgv1
- northernboy
- Apprentice MGer
Replied by northernboy on topic Throttle Position Sensor (TPS) Plug
Posted 5 years 3 months ago #191234
Thanks Dave but that partnumber if for the actual TPS, I need the plug that goes into the TPS. Thanks
by northernboy
- sworkscooper
Replied by sworkscooper on topic Throttle Position Sensor (TPS) Plug
Posted 5 years 3 months ago #191237
Hi . There is a seller on Fleabay called 3 Way Components that have a vast array of this type of thing . You might have to give them a ring to see if they have that type of plug .
https://ebay.co.uk/usr/3waycomp
I am useless at copying links on my phone but the above looks right .
John
John
by sworkscooper
- northernboy
- Apprentice MGer
Posted 5 years 3 months ago #191244
Thanks John - I have sent photos and a message
by northernboy
- sworkscooper
Posted 5 years 3 months ago #191246
I have found them to be excellent for sourcing the plug pins for the thermistor / temperature gauge plugs on my TF and our Classic Mini. It would be useful to give 3waycomp the make of plug unless they can identify it from your photo . Let us all know how you get on.
John
John
Last Edit:5 years 3 months ago
by sworkscooper
Last edit: 5 years 3 months ago by sworkscooper. Reason: Missed a bit
The following user(s) said Thank You: Jon-Mini
- northernboy
- Apprentice MGer
- sworkscooper
Posted 5 years 3 months ago #191250
No problem, pleased to help .
John
John
by sworkscooper
- northernboy
- Apprentice MGer
Posted 5 years 1 month ago #191519
Hello - just an update - fitted the new plug and all sorted - the TPS now works as it should and keeps the engine speed under control
thanks
thanks
by northernboy
The following user(s) said Thank You: cairnsys, sworkscooper
- sworkscooper
Posted 5 years 1 month ago #191521
Well done . Just goes to show how such a small item can give a real headache of a problem. I have just done a similar job on a TF with a termistor switch plug and terminals .
John
John
by sworkscooper
Time to create page: 1.474 seconds
