MGTF clutch noise
- kpainter65
- Journeyman MGer
My clutch seems to be rattling, when the car is cold, there is little difference between when the clutch is out and when the clutch is depressed. When the car is hot, there seems to be a rattle when the clutch is out that goes away when the clutch is depressed.
The car has done 55k km (allegedly) and I think it may be the release bearing, but as I haven't changed a clutch since 1973 (Austin Healey Sprite) I am very rusty in this area to say the least.
I have uploaded a short video to listen to but I don't know if it really helps - this is only my second TF so I don't know if this is a generic fault.
Please have a listen:
Thanks
Keith
- BruceTF135
Or maybe there is someone with more acute hearing than me
:nonod:
- kpainter65
- Journeyman MGer
Keith
- kpainter65
- Journeyman MGer
Thanks
Keith
If it is, then it will place constant pressure on the release bearing, and, as in my case, cause the release bearing supports to melt and colapse.
yes mine rattled when disengaged, and went quiet when pressing peddle down. Stayed like this for a year or two before release bearing failed, so might not be related.
I was always battling a sticking release arm during this time.
When i did the clutch, the arm was VERY tight to move, but still operated clutch fine.
It also may judder when moving off from an incline
regrds
Mike G4WAM
Clutch judder could be due to bad friction plate or thrust bearing
However could also be the hydraulics, though much less likely.
One other thing to check is the engine mounts, in particular the torque tamer.
When mine failed it was catastophic failure of the thrust bearing, due to the clutch arm sticking, and causing dragging on the thrust bearing.
My clutch plate, and cover were in great condition, with little wear.
I supose a sticking release arm could also cause juddering, so also well worth checking.
A worn clutch would show as a high clutch bite point.
1.should a good clutch(replaced like yours) work on the lower half of the clutch pedal travel ?
2.mine seems to be on the upper or last part of the clutch pedal travel -do you think that this suggest limited release arm travel? (perhaps sticking and causing the judder when in traffic)
3.did you follow a guide on the forum for your clutch replacement or use your own method?
regards
Mike
A juddering clutch to me would mean a worn out clutch, but normally with a worn out clutch, the clutch engages and disengages only when the pedal is fully depressed, only that last bit of travel towards the floor engages or disengages the clutch.
I replace the clutch in my wife's F this past winter. The clutch could only be engaged and disengaged when the pedal was almost fully depressed. It was a time consuming job but not difficult. I basically followed the how-to on Dieter's page, which is really a concise/condensed version of the workshop manual. The only thing I did differently was that I only dropped the gearbox side of the subframe.
[size=10pt]Mark[/size]
95 MGF
Mike
