MGTF Wheel rim sizes
Hi Decided to renew my tyre on my 2009 MGTF. Purchased new Falken tyres 215x40 16" for the rear and 195x45 16" for the front. Got the wheels off and took them for powder coating today. Having a quick measure of the rims they look to be the same width front and back which surprised me, I expected to see wider rims on the rear. Is this correct???
Thanks Phil
Thanks Phil
by Slatept
- SundanceUK
Wheels are the same all round, no pun intended!
Just the tyres that are different.
Sundance
Sundance
by SundanceUK
Thanks for that, just seems strange. Getting tyres is a bit of an issue in that non of the main stream manufacturers supply the same type of tyre in both sizes.
by Slatept
- SundanceUK
I have used both Falken and Toyo in the past. Falkens are a good all round tyre, but the ZE914's I believe are being phased out, not sure what they are being replaced with.
Toyo have recently replaced the T1-R pattern which some people have had issues with - including myself with the new TR1 tyres. I have fitted two of these on the rear and they seem to be pretty good in both wet and dry conditions.
Other makes are available, but depends on if you have 16 or 15 inch wheels.
Sundance
Sundance
by SundanceUK
The latest Falken tyre is the Falken Ziex ZE310 Ecorun got 2 215s and 2 195s. I'll see how they go.
by Slatept
- El gordo escoces
- Journeyman MGer
Always think the tyre pressure is more critical on the tf than the brand of tyre. If the rear tyres are much less than the recommended 36psi.you run the risk of spinning out.
Thanks for that I'll keep an eye on the pressures.
by Slatept
Time to create page: 0.989 seconds
