Clutch slave cylinder ?
Hi just found out my MG TF 160 2003 clutch slave cylinder is leaking doesn't look a bad job to remove and repair, so need to order repair kit ASAP are they all the same ?
by jelly
I am 99% sure they are the same.
While you are in there check out the clutch arm to make sure it is sufficiently lubricated and not putting pressure on the slave cylinder.
by talkingcars
