Trophy electronics playing up
After trying three or four times, it was normal and it started. This happened each time I stopped and I was worrying that I wouldn't get home. Now it is back in the garage, I can't get it to start at all.
A friend suggested it is alarm related and I should change the battery in the fob. I have done this with no effect.
I bought the car second hand and don't have the owner's manual. I have never bothered to lock the car or put the alarm on as a thief would rip the hood and hotwire. The fob buttons are so worn that I can't tell which is which. Neither seems to lock the car.
Any suggestions?
- sworkscooper
Do one fob and then the other.
John
Ps . There are replacement kits for both fobs on the Bay of E .
I will try that.
However the car has started Ok with the spare key which doesn't have a fob
- sworkscooper
John
I checked to see if pressing the buttons on the fob actually does lock or unlock the car and it doesn't.
This all points to a problem with the fob - presumably intermittent or how would I have used the car yesterday.
You said there are kits on ebay. can you point me to them. I have only found new cases without the electronics or secondhand ones
Thanks for taking the trouble to help me
- sworkscooper
I think I may have caused a bit of confusion here as it was the new case kits I was on about . I believe some on the forum have fitted new micro switches to these fobs when the fobs give this type of problem but may be wrong . You had said that you don't lock the car but I'm certain that F's have passive immobilisation so I can't understand how you can get the car started without pressing the fob unlock button. Unless a previous owner has by passed the Imobiliser at some point .
I can't offer much more advice really . A Pscan connected to your car might be able to re sync the fobs to the Imobiliser . Forum member Talkingcars might be able to give you advice as he has an F and is a knowledgable guy .
John
I think you were right about the spare key. I probably had the fob in my pocket when I tried it. It doesn't work with the fob left in the house.
Thanks again..
- sworkscooper
John
davidej wrote: If i buy a second hand fob to go with the spare key, will I be able to synch it to the car by pressing the buttons as you outlined in your first post?
No it has to be paired to the alarm ECU using T4 or www.pscan.uk ,you can only re-sync paired fobs.
I can sync and re-sync Lucas fobs if you bring your car to me.
If you are far away, could you do if I sent you the working fob as well?
